LS1 fan wiring ?
Subscribe
Jan 19, 2011 | 08:37 AM
Ok my car was orginally wired by Hawks. When i first put the new motor in the fans would not come on so I hooked them up to a switch. How do i wire it all back up? i hate wiring BTW...
Reply 0
Jan 19, 2011 | 01:12 PM
Re: LS1 fan wiring ?
Find the Fan-1 and Fan-2 control pins on your PCM pinout, and connect each to the ground side of each fan relay.
Or just take it back to Hawks.
Reply 0
Jan 19, 2011 | 01:19 PM
+1 to take it back to Hawks
If you must fix it yourself, use this
C100 G8 is for 90-92 cars. Your 87 has the fan relay fuse at C221 pin D assuming Hawks didnt move it elsewhere. For manual override Id still leave the PCM control but tee into those wires to a two pole toggle switch to ground. IGN on, switch off fans operate automatically under PCM control. IGN on, switch on, fans run continuously until IGN is turned off
Reply 0
Jan 19, 2011 | 05:43 PM
Reply 0
Jan 19, 2011 | 07:26 PM
The car was wired by hawks... 6 years ago, lol. Thanks for the help. I'll let you know how it goes.
Reply 0
Jan 20, 2011 | 01:30 PM
What on/off temp configuration does your PCM have? If it's the stock calibration, it may be hotter than you want.
Reply 0
Subscribe
