LS1 part identification help please
Old Jan 23, 2011 | 02:47 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Hey all,
I just bought an LS1 basket case and am assembling the engine for my gta. The guy had two donor cars and built one for his rx7 and had all the other stuff left over which basically equated to a machined and cleaned block and crank, as well as heads, intake and 3 rubbermaid bins of parts. with my having no LS1 experience, identifying everything i have is where i'm running into issues, which is where i need your help.
I've found all the engine diagrams on ls1tech to inventory everything I have except for the accessory brackets. can some of you supply me with photos of your factory power steering brackets and alternator brackets (preferably bare or off the engine)? i have determined that I have 2 ac brackets doing some ebay research (from a 4th gen camaro/transam) but can't identify anything else. any help would be greatly appreciated.
Thanks,
thunder
Old Jan 23, 2011 | 03:24 PM
Iroc'nthe87's Avatar
Re: LS1 part identification help please
This is essentially the LS1 f-body layout for the accessory drive (alternator bracket is bottom right)
Old Jan 23, 2011 | 03:35 PM
one92rs's Avatar
Car: SOLD!!!!!
power steering on the right alt on the left.
http://store03.prostores.com/servlet...PS-Pump/Detail
Old Jan 23, 2011 | 05:01 PM
thunder85's Avatar
Engine: 5.7L w/hsr
awesome.. thank you. this is turning out to be quite a task... if nothing else the bucket of bolts and small brackets is going to be a blast to figure out. is there anything that gives an index of what size/type bolts go where?
Old Jan 23, 2011 | 05:47 PM
one92rs's Avatar
Car: SOLD!!!!!
use bolts that go about 1" in the hole. also remember that it is aluminum also. if all else torque them to spec.
Old Jan 23, 2011 | 08:02 PM
Pocket's Avatar
Car: 91 Trans Am
http://www.compnine.com/index.php?t=...47577279&uid=1
Tons of exploded views here
Old Jan 25, 2011 | 10:44 PM
thunder85's Avatar
Engine: 5.7L w/hsr
thanks everyone
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1nastygta
Aug 8, 2015 07:38 PM
