Dumb 4th gen fuel tank swap question
Old Feb 6, 2011 | 11:54 AM
luvmy64's Avatar
Havent been on here in a while, but i just got another Camaro, and the gas tank is shot. I looked at the sticky and found a lot of useful info, but im thinking about doing something that may sound backwards.
Motor is stock tbi 305. If i bought a complete tank and sender from a 99-02, could i use the pump thats in it, even though it has more pressure than my stocker? I thought i read somewhere that tbi cars had an external regulator? So if thats the case, do i need to remove the 99-02 regulator like the guy showed in the sticky? Will the sender/pump wires just plug up or does anyone have a schematic?
Surely somebody has done this. The reason im thinking about going with the plastic tank is cost and not having to worry about it rusting again.
Old Feb 6, 2011 | 01:02 PM
Firebat's Avatar
Re: Dumb 4th gen fuel tank swap question
Will need to remove the LS1 regulator. The LS1 pump should work fine if the TBI setup has a regulator. I use a LS1 pump/tank for my LT1 fuel setup which should be the same as a TBI/TPI fuel setup.
The LS1 sending unit won't output the correct fuel level signal. Need GM part number #25319676 - sender out of a '97 Grand Prix.
May have to splice wires but we are only talking 3 wires. Ground should be black, the other 2 I don't know for sure from memory. http://92b4crs.tripod.com/86wiring/dia-pics/81-1.jpg
Old Feb 6, 2011 | 01:13 PM
luvmy64's Avatar
Thats what i was thinking.
Old Feb 7, 2011 | 11:08 AM
luvmy64's Avatar
I was looking at the dismantled regulator on the sticky, and i couldnt tell a lot from the pic......do i need to plug the place it came from, or just remove it and leave it alone?
Old Feb 7, 2011 | 12:30 PM
Firebat's Avatar
Only remove the ls1 reg, do not plug.
Old Oct 8, 2012 | 10:42 AM
92camaro_man's Avatar
luvmy64 did you get the swap working?
Old Oct 8, 2012 | 11:00 AM
what if i use a tank out of a v6, i would still just swap the sending unit with the 97 grand prix
Old Oct 8, 2012 | 12:08 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Yes and you dont have to remove the regulator, it isnt there.
Old May 20, 2014 | 05:26 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Sorry for digging up an old thread...
I'm about to swap out my rear end and thought about swapping my tank for 4th Gen LS1 tank. However, I probably won't be swapping to a LS motor for a few months. I have a TBI motor now can I run both fuel regulators?
Old May 20, 2014 | 05:43 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Not sure about running both regulators but if you get a V6 tank with pump you will need to run the Corvette style filter/regulator when you swap to LS. being as the V6 pump does not have a regulator.
Old May 21, 2014 | 01:34 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Thanks...I knew about the v6 pump not having the regulator...I guess I forgot the fuel pressure is enough to fuel a stock ls motor.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
reiderz iroc
Aug 13, 2015 04:57 PM
