Finally did something with the "latest" LS1 longblock
Old Mar 3, 2011 | 02:40 PM
  #51
five7kid's Avatar
Transmission: 4L80E/4L80E
Was it printed in ink, or embossed in the rubber? On the lip itself, or the support ring?
I was thinking about using silicone myself. Means I'll need to pull it out again (which I'll have to do if I get another seal), but I'd rather not risk a leak.
Oh, I forgot one other question I had. The lifters have the oil hole in the side, in line with the roller. Does it matter which way the hole faces? The galleys are toward the bottom of the lifter bores, I believe, but I'm guessing it doesn't really matter which way the holes face.
Old Mar 7, 2011 | 03:42 PM
  #52
five7kid's Avatar
Anybody have an answer to this one?
Old Mar 7, 2011 | 03:45 PM
  #53
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: Finally did something with the "latest" LS1 longblock
Doesnt matter which way the hole is positioned
Old Mar 7, 2011 | 04:11 PM
  #54
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
It was embossed in the rubber, on the flat side of the ring. I'd get a picture for you but I already put the trans on.
Old Mar 7, 2011 | 04:17 PM
  #55
five7kid's Avatar
Didn't think it would, but also didn't want to wipe out a lifter/cam.
Old Mar 7, 2011 | 04:18 PM
  #56
five7kid's Avatar
I think I looked at it hard enough to know it wasn't embossed in the rubber.
I picked up another seal, haven't opened the box yet. Got it from a different store, so we'll see if this one is marked.
Old Mar 9, 2011 | 10:28 PM
  #57
five7kid's Avatar
Finally opened up the package for the new seal. "THIS SIDE OUT" was clearly stamped in the lip. So, I pulled the installed one off again, looked it over very carefully again, it ain't marked!
But, I had tapped it back in after it popped out of the cover while reinstalling it last time, and apparently I got it properly seated that time. And, I had it in the correct way. So, left it in there, I greased up the lip, and put it back on (it didn't pop out this time).
Didn't have much time to work on it tonight, but the engine oil is draining.
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
