Plastic LS1 tank question
Old May 25, 2011 | 10:38 AM
blakecharles's Avatar
I have a plastic LS1 tank that I am putting in my 1989 Camaro along with a LS1 and T56. The stock fuel level sending unit reads 33-240 ohm (empty-full)...
Here is my question to you....
My new fuel gauge dose not read 33-240, it's 240-33 ohm. I was going to bend the float arm so that it faces the other way... Thus correcting the problem.
The fuel gauge would be accurate, but I thought the fuel level data was sent to the PCM for EVAP calculations... wont this throw off the EVAP system? This needs to be a smog legal swap.
Old May 25, 2011 | 11:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, it will throw off the PCM for its emissions functions.
The options are swapping in a 4th gen gauge cluster, or putting in a programmable fuel gauge (I did the latter in my LS1/T56 swap in which I used a 4th gen LS1 plastic tank). Since you said "new fuel gauge", sounds like you should have gotten a programmable.
Old May 25, 2011 | 09:43 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Plastic LS1 tank question
Mount the gauge upside down. LOL!
Old May 26, 2011 | 07:36 PM
Guess I will have to pay another $100 to convert to 0-90 ohms.
1 last question. I have a 1998 style LS1, but I was tld I will still need the platic tank. In 1998 a metal tank was still used. Is there any diff in the EVAP between 98 and 99-02??
Old May 26, 2011 | 11:53 PM
five7kid's Avatar
If you've got a '98 LS1 engine and emissions system, and a '98 LS1 tank, whoever told you that you need a plastic tank is simply dead wrong.
Leave the sender alone and use a programmable fuel level gauge, like you said you are going to do in the thread about plastic tanks.
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
