another 5.3 LM7 build
Old Jul 31, 2011 | 12:25 PM
  #51
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Re: another 5.3 LM7 build
man i got the worst feeling ever about this wiring...
Old Aug 2, 2011 | 04:20 AM
  #52
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
finally was able to dig out the camera so more pics are to come, don't mind the wiring, i ran out of supplies, but when i get some more i'm going to restart and organize!!!
Old Aug 2, 2011 | 08:58 AM
  #53
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
few pics...
Old Aug 2, 2011 | 08:59 AM
  #54
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
off topic pics,
my future lq9 project
hood i got
Old Aug 2, 2011 | 07:56 PM
  #55
Pocket's Avatar
Car: 91 Trans Am
Where are your wire labels? I cant make heads or tails of that rats nest
Pull all the pins back out, bundle the connector's wires and tag each individual one
Old Aug 3, 2011 | 01:52 AM
  #56
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
label every single pin, or every connector?
Old Aug 3, 2011 | 10:32 AM
  #57
Pocket's Avatar
Car: 91 Trans Am
Both, and bind the circuits together so if a tag falls off you can ID it by association
Old Aug 3, 2011 | 11:47 AM
  #58
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
it's gunna be a while before i get back around to the wiring. School starts monday
Old Aug 3, 2011 | 06:01 PM
  #59
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
ok poocket, quick question, how does the PCM batter supply hook up, does it go to the third gen harness, or does it go straight to the battery???
Old Aug 3, 2011 | 06:50 PM
  #60
Pocket's Avatar
Car: 91 Trans Am
Fuel pump fuse near the battery like the 3rd gen ECM used
Old Aug 3, 2011 | 07:12 PM
  #61
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
ok, can u tell me which pins go to the third gen harness, so i can leave them out of the looming? red and blue please!
Old Aug 3, 2011 | 07:54 PM
  #62
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
for those who want to do ur wiring urself, my advise is to either send it to pocket, or buy one from painless... either or are plug and play
Old Aug 3, 2011 | 08:03 PM
  #63
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
id go to Jon any day over painless, painless wont mate the harnesses as far as i know mines coming soon Jon!!
Old Aug 9, 2011 | 08:40 PM
  #64
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
found a ls1 harness from speedway motors for around 600 dollars, so if this wiring falls through i'll just order that one and send it and my third gen harness to pocket and let him fix it. I'm not doing wiring anymore if this one doesn't work
Old Aug 14, 2011 | 12:25 PM
  #65
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
does anybody know the specs of the motor mount bolts that go on the motor?
Old Aug 14, 2011 | 01:04 PM
  #66
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
37LBS This is the bolts that hold the motor mount to the block.
Err... Just rereading, I have no clue on the bolt specs.
Old Aug 14, 2011 | 02:19 PM
  #67
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
really needing the specs
Old Aug 14, 2011 | 02:30 PM
  #68
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I just google searched it and I found it in 1 sec
http://ls1tech.com/forums/generation...ls1-block.html
Old Aug 14, 2011 | 02:47 PM
  #69
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
what would people go without google... will i be able to pick these bolts up at a hardware store?
Old Aug 14, 2011 | 03:02 PM
  #70
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yes
Old Aug 14, 2011 | 03:19 PM
  #71
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
freakin sweet!
Old Aug 17, 2011 | 02:10 PM
  #72
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
school sucks...
Old Aug 19, 2011 | 10:59 PM
  #73
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
is this where you're talking about putting the PCM battery supply?
Old Aug 20, 2011 | 03:53 AM
  #74
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Just a quick question for you...and please don't take this the wrong way....but why would you use that rusty, crashed, beat to heck shell for an LSx swap? To be honest with you, $500 seems like a lot for that. I have a freind selling an 87 305/5 speed TA for $850 right now....rough around the edges and high miles, but minimal rust and a solid platform to build on. I would start with a better body before getting too involved. Has the car even ever been checked for straightness?
I understand that you may be on a tight budget, but I left my good old 305 in my car for years before I finally had the cash to correctly do an LSx swap. It's not cheap no matter how you slice it, so I would def think about EVERYTHING you will need, and if you have to cut corners at all, just wait till you can do it right. It's easy to buy a motor and think you spent the major money already, but the engine itself is probably one of the cheaper things you'll need for the swap. To give you an idea, I paid $800 for my engine, but the harness and PCM will cost me $700 alone. The K member and trans crossmember were almost $900. It gets expensive quick!
Like I said, don't take any of this the wrong way. Just something I figured I'd throw out there. Oh and BTW, if your only running a 4.8 with a cam, a FAST manifold will be overkill and WAY more money added to the build. Go with an LS6 manifold....it will flow all you'll ever need for the 4.8.
Old Aug 20, 2011 | 05:12 AM
  #75
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
wow, this one hits close to home...I was raised in Evergreen And I live in Montgomery...nice to see you tackling this...ill definitely be watching!!
Old Aug 20, 2011 | 11:42 AM
  #76
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
car is straight... and car has ONLY 14,000 miles on it... it's been sitting up for years in the weather... i got my 4.8 with wiring and PCM for a 350, and a 305. i'm swapping 5.3 internals into the 4.8 with the 4.8 pistons to make it HO, heads, cam, intake, all of that is going on it. but i am going with the ls6 intake until i can find a fast 92... buddy of mine had the same setup in his car with the fast 90 and made a little over 400 HP. i know this swap is going to be expensive and i am on no budget... it's going to kick off in january, as i will have more money to throw away on it. I, myself, had a body man look at the car and he said that he didn't see anything wrong with the frame being warped... I got a car, with 14,000 miles on it for 500 dollars, u won't find that everyday. even has the '94 tag on it
Old Aug 20, 2011 | 12:18 PM
  #77
Car: 1986 Trans am
Engine: 5.3 LM7
Are you sure the odometer didn't roll over once or twice since they only have 5 digit odometers? That car does not look like it has 14K miles on it. Either way, I would have just thought that you would want to start out with a nicer body if you plan on putting all this time and money into it for an LSx swap. Especially if you have no budget.
Old Aug 20, 2011 | 12:20 PM
  #78
Pocket's Avatar
Car: 91 Trans Am
http://i869.photobucket.com/albums/ab260/firebirdboi79/1990%20camaro%20rs/DSCN0474.jpg
That is the factory power dist block. I use a S10 5 pole block, but the purpose is the same. All of the the power wires are moved to the power block, instead of having some there and the rest on the starter
Old Aug 20, 2011 | 12:23 PM
  #79
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
na, i wanted to take a pile and turn it into something great... that's just how i think...
  #80
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
I'll PM you when i order the other harness...
Old Aug 20, 2011 | 06:37 PM
  #81
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
well got most of the third gen harness removed today, not sure how to remove this how do i remove it? do i just chop it or what?
Old Aug 20, 2011 | 07:14 PM
  #82
Pocket's Avatar
Car: 91 Trans Am
Inside the car, remove the pass hush panel and drop the ECM. Near the ECM is a small pigtail running into the dash, thats the C207. Unhook those and follow the harness to the fender. Remove the plastic C-clip, push the retainer in and the grommet will pop out and the bundle can be pulled through
Old Aug 20, 2011 | 11:31 PM
  #83
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
well i got the third gen harness out and removed all of the looming harness isn't in the best shape every, being out in the weather for 3 years cracked almost all of the insulation around the wires...
Old Aug 21, 2011 | 07:32 AM
  #84
Pocket's Avatar
Car: 91 Trans Am
As long as the C207 is intact and theres atleast 12" of good wire from the C100, its usable
Old Aug 23, 2011 | 07:53 PM
  #85
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
the C207 is in tact... and i believe i have more than 12" (inches) of wiring from the c100
Old Aug 25, 2011 | 09:49 PM
  #86
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
guys, goin to ford, sellin the motor, but keeping the car, will do this swap later on when funds are avaliable
Old Aug 25, 2011 | 11:22 PM
  #87
you know they make medicine for that, right?
Old Aug 26, 2011 | 01:00 AM
  #88
Car: 1986 Trans am
Engine: 5.3 LM7
Hate to sound like the A-hole here, but I saw that coming...
Old Aug 26, 2011 | 06:13 AM
  #89
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Lmao!
Old Aug 26, 2011 | 09:52 AM
  #90
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
Yeah, I think the guy was in a little over his head. Its ok, I too used to dream big when I was younger.
I read all these LS1 swap threads, I'm still working on buying a donor car. I'm willing to pay good money for one, so hopefully it works out.
Good luck with the Fords 1FSTBRD, don't give up on hot-rodding!
Old Aug 29, 2011 | 11:37 AM
  #91
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
hey hey hey, i got further than i thought... wiring is all together and back in the car, waitin on the starter and PCM to get here to see if i actually helped or hurt myself... more to come guys stay tuned
Old Aug 29, 2011 | 01:52 PM
  #92
Thridgen60's Avatar
Car: 86 Camaro
Engine: 6.0L LQ4
Transmission: 4L80E
Axle/Gears: 9 inch, 3.50
Well i just read this whole thread and man was that a crazy ride!! I think you have decided to sell the motor/car and/or give up on it like 6 times. Then out of nowhere you make big progress on it. Keep with it man and dont give up so easy, it will be worth it in the end.
Old Aug 29, 2011 | 02:35 PM
  #93
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
yea it has been one heck of a ride, but like i said, i won't know if i did good or not until i get the PCM and starter, which if everything goes like it's been going will be a while, i'm still debating on selling the 4.8 and going straight to ls1. But i'm not sure yet. i still do not have the motor mounts, fbody oil pan, or ls1/ls6 intake but i'm just doing a mock up right now to see if the wiring is correct
Old Aug 29, 2011 | 04:21 PM
  #94
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
yea it has been one hell of a ride, but like i said, i won't know if i did good or not until i get the PCM and starter, which if everything goes like it's been going will be a while, i'm still debating on selling the 4.8 and going straight to ls1. But i'm not sure yet. i still do not have the motor mounts, fbody oil pan, or ls1/ls6 intake but i'm just doing a mock up right now to see if the wiring is correct
Just keep the 4.8 as is, add a ls1 oil pan, ls6 intake, and reuse ur 700r4.... and youll prob. Be recieving an email from a mod about cussing on tgo... I know I did
Old Aug 29, 2011 | 04:28 PM
  #95
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
what happened to "if you got a problem research it, i'm not helping you out anymore." seriously dude i appreciate u tryin to help out, but after what all you've told me it'd be best if u didn't... i'd rather do some research then take ur advise now
Old Aug 29, 2011 | 06:39 PM
  #96
five7kid's Avatar
Transmission: 4L80E/4L80E
Actually, I believe it requires surgery. . .
Old Aug 29, 2011 | 06:41 PM
  #97
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
lol yea, i had to sit back and think on it for a while, but finally decided that it would be cheaper gettin the 4.8 to run in the camaro, then buying a mustang, then buying a motor and harness...
Old Aug 29, 2011 | 11:23 PM
  #98
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
thats fine with me... sending me 8-15 questions a day.. honestly gets old. i remember you asking me a different question every day where did i get my intake from, my cam from, my headers from, etc. asking me if my car was a berlinetta or a sport coupe 3-4 times within 2 months, asking me where did i get my hood 3 times, asking me MANY times to come basically rewire your harness, i could go on for a while.... i believe your in over your head for a 16 year old high school kid...with no job.. but what do i know i drive a sport coupe slow camaro.. have a nice day
Old Aug 29, 2011 | 11:34 PM
  #99
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
first off dude, ur camaro looks like spit... and i'm 17... and like i said a long time ago i don't need ur advise if ur gunna be a douche bag about it, and if i really wanted u touching my car or helping me out with it i would have found someway to pay you, so the best thing u can do is stay out of my business and I'll stay out of yours... understand, or do i need to type words that you can actually understand?
Old Aug 29, 2011 | 11:43 PM
  #100
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
well 1. i counted 4 times within the past 3 months you said "car looked good last night" or "man that cars sick" 2. you have offered me money to come over and rewire your harness and i didnt reply to you 3. i understand your words mr. 10th or 11th grader?..... being ASE certified as a mechanic helps me "understand" your words too. thanks for going easy on the words there
