How to swap a gen 1 sbc intake on a lt1?
Old Jul 8, 2011 | 12:26 AM
lt1b4c's Avatar
Car: Iroc 88
Engine: 350 LT1
Axle/Gears: 10 Bolt 4:11
I've been researching some post online and I was wondering if all that is needed is to re-drill the bolt holes in the correct location to match the Lt heads on a gen 1 sbc intake? I was looking for a different intake choice other than the carb'd gmpp Lt intake since i plan on doing a blowthrough setup. I was planning to run the Edelbrock Vic. Jr. Any help would be greatly appreciated.
Thanks J.R.
Old Jul 8, 2011 | 04:18 AM
Guest
Guest
Posts: n/a
Re: How to swap a gen 1 sbc intake on a lt1?
I believe your best bet would be Edelbrock's Super Victor Vortec.
Old Jul 8, 2011 | 10:21 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The previous owner of my Vic Jnr E intake had it on his LT1
His notes
"The overlap between SBC and LTx patterns makes 4 of the bolt holes unusable.
I didn't put forth the effort to weld up the holes and redrill (or do the same to the heads), so I sealed those holes off on the intake with NPT plugs.
The center 4 holes are the ones I drilled and threaded in my heads to suit the intake.
I had no sealing issues with this, using Mr Gasket brand "race" gaskets
You have no coolant to intake so you don't need a bolt either side of the coolant passages for sealing like you do with a Gen 1 engine .
You could do as you say and redrill the center 4 holes to suit LT1 pattern
Old Jul 8, 2011 | 10:53 PM
lt1b4c's Avatar
Car: Iroc 88
Engine: 350 LT1
With the super Vic E, vortec, does it require anything with modifying the bolt holes, or the angle of the bolts?
Old Jul 10, 2011 | 01:51 AM
lt1b4c's Avatar
Car: Iroc 88
Engine: 350 LT1
bump, anyone??
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
