Fuel Pump question. Carb car going ls FI
Old Jul 12, 2011 | 11:19 AM
Speedfreak391's Avatar
Car: 87 iroc Arctic White w/gold ss stri
Engine: Turbo'd 5.3 in process
Transmission: T-56 w/SPEC stage 3+ clutch
Axle/Gears: 9" Moser w/3.25's
Here is my predicament. I have a 87 305 carb car, that I am putting a turbo'd 5.3 in. Now the stock fuel system doesn't have a in-tank pump. But I am looking at running twin walboros gss340's in the tank. Or, should I just run a big external pump.
Do I need to sump the tank?
If I run the twin in-tank pumps what do I mount them to? I don't think the sending unit hangs down in the tank, or does it?
Old Jul 12, 2011 | 05:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The sending unit hangs down into the tank.
I'm not familiar with mounting dual in-tank pumps. Perhaps it has been done. Maybe the Power Adder types? I believe I've heard of it with the 4th gen LS1 tank, but couldn't provide any details.
It would seem sumping the tank would be the easiest solution.
Old Jul 12, 2011 | 06:32 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Fuel Pump question. Carb car going ls FI
you may want to double check the in-tank setup - my carbed 87 had the a helper pump in the tank. however, i opted to grab a newer tpi unit so i could use a normal FI pump and ran with the walbro 255.
the sending unit opening's pretty tight for a single pump as-is, probably best to run a sumped setup so you're not restricted by the stock provisions. or run with a 4th gen tank and go with some of their dual pump options
Old Jul 12, 2011 | 08:56 PM
Thanks for the help guys but I think I found what I need as far as info. Check out this setup. I already have the pumps, now all I need is the lines. I will be ordering them tomorrow.
Check out the thread below.
https://www.thirdgen.org/forums/fabr...al-walbro.html
Old Jul 13, 2011 | 08:41 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Your target power output will tell you if you need dual pumps or not. I run a single 255 in tank pump on my magnacharged LS1 at 7psi boost and the pump keeps up fine.
Old Jul 13, 2011 | 01:18 PM
five7kid's Avatar
Originally Posted by Speedfreak391
That eliminates the fuel gauge sender, if I'm seeing it correctly.
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
