Conversion idea... come inside!!
Old Sep 22, 2011 | 12:53 PM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Ok, I have a 1988 IROC-Z that I want to do the following:
LSx (either 6,7 or built 1) and the 6 speed auto tranny from a CTS-V with paddle shift. I'd like to know if anyone has done this and if so, what kind of issues did you have?
Old Sep 22, 2011 | 02:43 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Conversion idea... come inside!!
I'm not aware of anybody installing a 6L90 into a thirdgen yet. There aren't many car versions out there, and those that are tend to be quite expensive. Keep in mind that if you go this route, you're going to need the computer from a 6L90 vehicle too. I doubt that an older ECM that was only tasked with controlling a 4L60 or 4L80 will be capable of controlling the 6L90. Fortunately, there aught to be about a billion 1500 Silverados out there by now with it. I'm not familiar enough with 2WD trucks to be sure, but I'd imagine that a motor/trans from a late model 6.2 1500 Silverado would probably be your most affordable route, but that's going to be just as rare as something from an SS Camaro or CTS-V.
Old Sep 22, 2011 | 02:57 PM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Interseting concept, wondering if an aftermarket control system is available for that trans? It'll be costly that is for sure....
Old Sep 22, 2011 | 05:52 PM
Pocket's Avatar
Car: 91 Trans Am
Good luck getting a driveshaft for any CTS or 2010+ camaro trans
Itd be easiest to convert a LS1 to gen IV with the newer trans or start with a GEN IV engine. Remember GEN IV uses separate ECM and TCM's, unlike the GEN III that grouped them together in one unit. Also, all GEN IV are DBW, which IMHO is annoying
Old Sep 23, 2011 | 10:05 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Definitely a pita to install but they are easier to tune
Old Sep 23, 2011 | 12:35 PM
wgpengineering's Avatar
Car: 1984 Camaro
Engine: 305 HO/ soon to be 4.8L LR4
Transmission: 700R4/ soon to be NV4500
Axle/Gears: Ford 8.8 w/ 3.73 posi
I haven't used it myself, but TCI Auto has a six speed tranny that you can get paddle shifters or like a sport-tronic type (thats what the description makes it sound like) setup for...
here is the paddle shifter setup: http://www.tciauto.com/tc/6x-six-spe...e-shifter.html
and here is the sport-tronic setup: http://www.tciauto.com/tc/6x-six-spe...m-shifter.html
both setups are capable of 850HP and the best part is they are new and i'm sure they come with some sort of warranty...
yea they are $6k, but it includes transmission with bellhousing, transmission control unit, paddle shifter or 2-button shifter, wiring harness, transmission cooler, dipstick & transmission fluid...and it uses the 4l80 tranny case so you know it'll fit
Old Sep 23, 2011 | 01:10 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
I believe there is a build thread on the southwest forum the screen name is darknw90rs he got a crashed 2011 supercharged CTS-V with the same trans and he is transplating everything over to an El Camino i dont know how far along he is but check it out he may be able to answer some of your questions
Old Sep 23, 2011 | 02:06 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
the 6l80 is larger than the 80 and the 80 is about as big as you can fit without modification
Old Sep 23, 2011 | 09:48 PM
Pocket's Avatar
Car: 91 Trans Am
Im using an '80E and IMHO the trans tunnel needs to be modified for it to fit properly
Old Sep 24, 2011 | 02:39 PM
Car: 1988 Iroc-Z
I'm thinking that an after market plug n play type tranny install would be the best way to go. I'm not to concerned about the engine at all, thats a small decision will come after I figure out if the '90 setup will go smoothly... Not really concerned about the price for the most part, I'd just like to go over 200 w/ an auto setup and I love the idea of the paddle shifters
Old Sep 24, 2011 | 02:55 PM
Pocket's Avatar
Car: 91 Trans Am
Where exactly would you be able to go over 200mph?
Old Sep 24, 2011 | 02:58 PM
Car: 1988 Iroc-Z
Texas mile... I'd make the trip to do it for sure
Old Sep 24, 2011 | 04:06 PM
Iroc'nthe87's Avatar
Old Sep 24, 2011 | 05:14 PM
J91's Avatar
J91
Oh my.....
Old Sep 26, 2011 | 04:05 PM
Car: 1988 Iroc-Z
What? Never had the ambition to do 200mph and get a t-shirt for it? lol I agree, its an expensive *** t-shirt, but it'll be very well worth it...
Old Sep 26, 2011 | 05:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
And has to be DOT tires. Not many DOT tires rated for 200+ MPH.
There's video of a pretty serious Vette crash there. They tried to use drag radials on all four corners. Not a pretty picture.
Old Oct 4, 2011 | 02:23 AM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I can see it already....Oh wait already did.
http://www.youtube.com/watch?v=m3cI6Eqj_d0
Old Oct 4, 2011 | 06:33 AM
J91's Avatar
J91
Oh my.....
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
