94' 9c1 lt1 Swap / 86 Iroc-Z28
I got a 9c1 engine and ecm im planning to put into my 5 speed carberated camaro im just wondering if its worth changing carberated to this engine? and is their anything i should look out for?? all help is greatly appreciated
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
If I'm understanding you properly, you're asking if it it worth it to go from a carbureted engine, to an EFI LT1.
ABSOLUTELY!
Everything you need to look out for is documented in the LT1 swap sticky.
ABSOLUTELY!
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: 94' 9c1 lt1 Swap / 86 Iroc-Z28
It will be worth it, no idea on what is different on Carb 3rd gens but I figure Fuel lines and Gas tank? Everything else should be a plain lt1 swap.
No in-tank electric fuel pump or relays, no in-line fuel filter, fuel lines different.
I converted two factory carb'd cars to LS1, for what that's worth.
1992 Trans Am
Aug 8, 2015 08:16 PM
