5.3 + 700r4
Old Nov 7, 2011 | 07:57 PM
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
5.3 + 700r4
what type of torque converter will make it work
Old Nov 7, 2011 | 08:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Re: 5.3 + 700r4
One for a 700R4. You need a flexplate from a Truck engine with the 4L80E and the crank adapter.
Old Nov 7, 2011 | 08:54 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 5.3 + 700r4
Why is everyone so dead set on reusing old crappy/weak trannys behind the new engines when better ones are commonly available. Individually, the conversion parts arent expensive, but add them up and they're almost as much as it would cost to buy a good used 4L60E trans
Crank adapter
Special longer bolts
Flexplate
Lock up kit
Custom length TV cable
TV cable bracket
VSS conversion parts
etc
Old Nov 8, 2011 | 05:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Amen!
In '09 I was looking into the possibility of putting a "spare" LQ4 into Berlinetta #1, using my existing TH700 (since I didn't have a tranny to go with the LQ4). I just couldn't get there, and ended up bartering away the LQ4 (a decision I now regret). Later that year I came across the LS1/4L60E dropout that is now in the car, and the superiority of that tranny is absolute.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
