to use all my standard sensors, i have to use a 97 lt1 cluster so everything functions correctly.
picked one up off craigslist for cheap so i would have a backup in case anything should ever happen to mine.
guy has a 97 30th anniversiary, but the part# on the cluster pulls up several threads on issues with the tripometer. from what i read, it looks like its a 99 model cluster.
the temp gauge is also 100-210-260 where is my current one is 160-210-260.
09380711
176414
0918
CYLJ are on the tag on the back. there is also a upc code on the back that is hard to read. is that the vin to the car? trying to figure this out so i can keep it for a back up or sell it.
thanks.
09380711
176414
0918
thanks.
http://ls1tech.com/forums/new-ls1-ow...-question.html
Its a 99 cluster and will not accept your analog senders. It will accept the serial data stream from the PCM though
Tags 88, cluster, instrument, instruments, iroc, z28
