need help
Old Nov 30, 2011 | 11:37 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
need help
i need to figure out pistons and cam for my 6.0l build. i am using a truck 6.0 block,l92 heads,fast 102 intake,injectors,and throttle body.car is t56 with 373 rear gears.was told to go with diamond but after a long wait was told to wait again. if someone can help me out it would be great.might even get to drive car next summer
Old Dec 1, 2011 | 09:54 AM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
Re: need help
I'm no expert on the L92's but I'll throw in my two cents. The general consensus is they respond really well to smallish cam's. That's where these heads shine in making large power while retaining drivability. The intake ports and valves are huge, so too much duration and intake lift with a lot of overlap is going to cause bad reversion and really isn't needed. Oddly alot of the off the shelf grind, small cam's seem to favor lift on the intake. I don't speculate this is necessary and feel more exhaust lift would be more beneficial. I would like to see some dyno comparisons to confirm this though.
There is a huge post over on LS1 tech debating cam profiles that I gathered a little solid info from, along with a lot of peak number, dyno queen bs that seems to be popular over on tech.
Ultimately it comes down to your needs, wants and intended application.
I chose the overlooked Katech Torquer LS3. Seems to hold great vacuum and make great broad power while having a nice mild lope still. Also doesn't have a very agressive lobe profile so it might help the springs live easier. Ultimately it looks like a great, livable daily driver street cam. If I was building a drag car however that's going to primarily be tuned to operate within a narrow power band, that choice would be completely different.
Old Dec 1, 2011 | 04:01 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: need help
have you already bought the intake? if its just a stock 6.0 and L92 heads, it may be a bit overkill. i've got a similar setup and opted to stick with the ls3 intake to save some coin (that 102 seems to be better for biiiiiiiiig cube swaps).
Old Dec 22, 2011 | 11:59 PM
driver101's Avatar
Re: need help
i got almost everything went with comp cams 54-470-11
diamond pistons,this should be a monster just need to get more cash and will pm pocket for a harness.thanks for the input
