98 ls1 harness pcm repin to work with a 99+ pcm
Old Dec 6, 2011 | 12:19 PM
gregX10A's Avatar
Car: 1989 pontiac firebird formula 350
Engine: 5.7l tpi
Axle/Gears: gm 10 bolt/3.73 gears
Hey guys I'm doing an ls1 swap into my 89 firebird and I have a 98 camaro donor car. The thing is I don't want to use the 98 pcm and would rather use a 99 or newer pcm. I heard you can repin the 98 harness to work with the 99 pcm, is this true? And if so is there anything else that needs to be done to the harness or engine?
Old Dec 6, 2011 | 01:00 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 98 ls1 harness pcm repin to work with a 99+ pcm
there is a ton of wiring info over here:
http://lt1swap.com/wiringharness.htm
many 98 owners do this for better tuning help/resources
label everything you can on the 98 harness and double check your work. just unpin and follow the 99+ fbody schematics and you should be good
Old Dec 6, 2011 | 09:23 PM
Pocket's Avatar
Car: 91 Trans Am
Yes the 98 harness can be used to build a 99+ swap. Anything else? Yes, Id suggest taking it apart and sorting through whats needed and whats not, then rebuild it to fit your engine bay the best
Old Dec 7, 2011 | 08:52 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Ive done this before and it works fine.
I have a pinout step by step in word if you want it.. just send me a PM it was from chipsbyal or something like that. he recommends making some wires longer
Old Jul 18, 2012 | 04:38 PM
gregX10A's Avatar
Engine: 5.7l tpi
Thanks for the info guys. I will be labeling the harness and will be remove things I dont need and get ready to mock it up as soon as I get the short block back from lme.
Old Jul 18, 2012 | 10:54 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The link below has pinouts for engine PCM. This will help you figure out what wire to run to which location on '99 ECM.
http://www.ls1tech.com/forums/conver...swap-faqs.html
You'll have some wires that are not needed that were part of emissions system and such. Don't pull those wires out of the PCM connector or water will get in through the holes where the wires used to be. Just snip the wires about a foot from the PCM connector, tape, and bundle out of the way.
Old Mar 18, 2016 | 09:51 AM
1fas92's Avatar
Car: 1992 Z28
Engine: Forged LS3
Transmission: T56 stage 2 clutch
Axle/Gears: 35 spline with 3.55 gears
Hello,
Can I get this info if you still have it ?
I have a buddy that I am trying to help .....
Thanks ,
Robbie Sheffield
Old Jun 6, 2022 | 08:37 PM
L1lone's Avatar
I am in need of the repin step by step please.
My ecu is fried on my 98 5.7 ls1 and can only find the 99 5.7 ls1 ecu. I really need my car up and going. Thank you in advanced.
Michelle
midge54
Dec 27, 2019 04:14 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
