Fuel Sender Line ID
Old Dec 16, 2011 | 09:35 PM
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
Fuel Sender Line ID
I am installing custom fuel lines. I know the feed line but which of the other three is the return. Can i block the other two and run a vented cap?
Old Dec 16, 2011 | 11:04 PM
rock861261's Avatar
Re: Fuel Sender Line ID
are you using the 4th gen tank? if yes top is feed the middle is vent and bottom is return
Old Dec 17, 2011 | 08:49 AM
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
No sorry 3rd gen but orig lines were missing when i bought car (prev owner started to repair floor) and i am running braided steel lines to a corvette filter for my 5.3 swap
Old Dec 19, 2011 | 05:31 AM
Pocket's Avatar
Car: 91 Trans Am
3/8" feed 5/16" return, rest get capped
Old Dec 19, 2011 | 06:35 PM
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
Thanks Pocket
Are there any concerns running all braided steel lines?
Old Dec 19, 2011 | 07:07 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
quite a few of us are doing it. i had a carbed setup originally, so my lines were no good.
the cheaper braided stuff can seep fumes over time, but mine's not been together long enough to have that problem....
Old Dec 19, 2011 | 07:21 PM
pumper.atv's Avatar
Car: 87 Z28
Engine: Truck 5.3
Any tips for making braided lines?
Thanks again for all the help
Old Dec 19, 2011 | 08:25 PM
rock861261's Avatar
they are really easy I just made some for my trans... when you cut them use black electrical tape and tape the hose as tight as you can then use a cut off wheel run some compressed air through them and spin on your fitting remember it has reverse threads make sure it bottoms out on the fitting and lube the other side of the fitting and screw it in done...
Old Dec 21, 2011 | 11:29 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Heres a dumb question and i feel retarded for asking this but i have a vette filter and which is the return and which is the feed line for the filter as I completely forgot which is which
Old Dec 22, 2011 | 06:27 AM
Pocket's Avatar
Car: 91 Trans Am
Good call on the tape. The fitting caps are left hand thread when you first put them on the hose. Threading the fitting onto the cap, its standard RHT
On the vette filter/regulator, feed is 3/8", return 5/16". Your fittings will only fit one way
Old Dec 22, 2011 | 07:54 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I had good luck using a chop saw with a large cutoff disc. tape up like others recommend to reduce fraying. use a light touch of oil on the threads to reduce cross threading and binding.
theshackle
Mar 5, 2017 06:37 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
