Lsx swap question
Old Jan 17, 2012 | 11:40 PM
projectredsled's Avatar
Lsx swap question
I'm bouncing around the idea of ditching my 305 for an lsx motor (instead of a 350 or 400). I currently have an 87 Camaro with 5 speed. Would it be possible to reuse my current trans with an lsx until I get the money together to pick up a 6 speed?
If it is possible, do I reuse my crossmember and flywheel?
I know that the t5 won't hold up to the increase in power for long but if I drive it conservatively until infer the 6 speed would everything else bolt up?
Thanks for the help guys
Old Jan 18, 2012 | 12:35 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Lsx swap question
no the trans will not work
Old Jan 18, 2012 | 09:00 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Actually, the trans will work. The way I have seen it done with the best success is with a 621 bellhousing, LS1 clutch, etc. Howe racing throwout bearing, and LS7 pilot bearing. You will need to figure out how to create a shifter to correct the 17* angle of the factory mounting, but it can be done.
Old Jan 18, 2012 | 09:11 AM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
yeah, sure you could make it work. but by the time you get it all sorted out i bet you'd be over half the cost of just picking up a used t56 and doing that, which will also be a ton easier. just wait to swap until you can do it with the t56 and not waste money on a t5 thats not gonna stay long anyway.
Old Jan 18, 2012 | 09:14 AM
1985WS6TA's Avatar
Car: 1985 WS6 Trans Am T-Top
Engine: 355 TPI N/A
Transmission: Borg/Warner T-5
Axle/Gears: 3:42
Does the T-5 26 spline input shaft match the 26 spline LS T56 26 spline shaft??
If it was me, I'd just save up and find a T-56 right away. Why go to all that trouble getting those parts when you can find a decent T-56 for $400-$1200 ready to go. Remember though, you need a 98+ T-56 if/when you do it.
Old Jan 18, 2012 | 09:14 PM
sounds like i should just keep stacking parts until i have everything ready to go in. Thanks for the info guys
Old Jan 18, 2012 | 09:18 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Like the others say find a t56. You'll even get another gear over that t5!
Old Jan 18, 2012 | 09:42 PM
I thought that the 93-97 t56 was the one that was a direct bolt in (other than crossmember)? and that the 98+ required changing alot of stuff
Old Jan 18, 2012 | 09:46 PM
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Lsx will bolt up to 98 to 02 t56
ltx will bolt up to 93 to 97 t56
Corvette and gto t56 will require quite a bit of changing to make work. 98 to 02 is what you need
Old Jan 18, 2012 | 09:55 PM
wow....i knew that. forgive my stupidity..lol
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
