Ltx fans for Lsx swap
Old Jan 29, 2012 | 05:50 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Can the fans and radiator be used out of a ltx car or a Lsx swap in a 85 camaro?
Old Jan 29, 2012 | 06:41 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Ltx fans for Lsx swap
Sure can. I used a radiator from a 97 formula. All I did was drilled a whole for the coolant drain plug. You will have to get new hoses that fit accordingly. And try to get the shroud with the radiator, your single fan shroud won't fit.
But you will have to do some wiring, since I'm assuing you have a single fan. And I'm not sure what all you have to do there. Pocket moddified my harness to use dual fan
Old Jan 29, 2012 | 07:38 PM
Pocket's Avatar
Car: 91 Trans Am
Itd be easier to skip the LT1 rad and just use the fans. Even the V6 3rd gen rad is thicker than any of the 4th gen rads
Fans use the same motors and control as 3rd gen fans, just a different shroud
Old Jan 29, 2012 | 08:49 PM
motenkjr's Avatar
Car: 1985 Camaro
Engine: 305 ci
Thanks guys. I'll see if the guy still has the fans
Chuck84TA
Jul 15, 2016 09:05 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
