Fuel system
Old Feb 6, 2012 | 08:13 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Fuel system
1984 Trans Am
370ci forged LQ4
Ported/milled LS3 heads
237/249 .6xx/.6xx 110+4 lsa
Ported victor jr
950 holley
NX plate wet plate kit
I am going to be running a inline fuel pump with my factory carb'd fuel tank. My question is, How do I run the line for the wet kit? Can I run a line from the stock fuel pickup to the pump then run the line to the front of the car. At the front of the car I can put a Y in the line running one side to the fuel solenoid and the other to the fpr for the carb?
N20 solenoid--plate kit
fuel tank--pump---filter-----<
FPR---carb
Tell me if that sounds right. I plan on dead heading the fuel pump and not running a return.
Let me know if you see and changed that need made.
Thanks,
Dustin
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
