Here's the plan:
Old Mar 25, 2012 | 10:22 PM
MuhThugga's Avatar
Car: 2005 GTO
Engine: LS2
Axle/Gears: 3.73 LSD
Here's the plan:
I recently have acquired a 4.3 baby LT1 and a 5.7 LT1, both for free. My plan is to take the crank and rods out of the 4.3 and stick them into the 5.7 to make a 302.
Now, this is where it gets fun: I'm also going to delete the Opti and use a regular distributor with a converted Gen 1 single plane intake, swap the firing order to 18726543, and stick her into a stick TPI car so I can continue to run the EFI system with MPFI.
Basically, my end goal is to have an EFI, hydraulic roller 302 Camaro that spins to about 8K for running around the curves.
A true RS thirdgen, if you will.
Thoughts?
Old Apr 3, 2012 | 02:02 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: Here's the plan:
I wouldnt want to spin it to 8k on a stock rotating assembly...
Old Apr 3, 2012 | 07:47 AM
MuhThugga's Avatar
Car: 2005 GTO
Engine: LS2
3" stroke, long rods, and the LTX stuff is stronger than the Gen 1 stuff. I don't see it as being a problem, especially with switching the firing order to 18726543
Old Apr 3, 2012 | 03:52 PM
Car: 1979 Malibu
Engine: Blown LSx
I dont consider 5.7" a long rod, that makes for a piston with a long compression height, combined with the fact that its a cast piston. swapping 4&7, and 2&3 will help, but we have only seen major improvments on indivual runner applications such as a sprint car engine. Not sure if the 4.3 crank is cast or steel, but honestly, I would want either in my engine. Also be kind of interested on seeing a hyd roller cam spin to 8000....
Old Apr 3, 2012 | 04:10 PM
MuhThugga's Avatar
Car: 2005 GTO
Engine: LS2
5.94" rods.
Forged crank and rods. Lighter and stronger than Gen 1.
crafty_z28
Members Firebirds
Jun 14, 2015 09:59 AM
Bowtie_Guy
Jan 18, 2015 08:22 PM
AFreeBreather
South East Region
Dec 10, 2014 09:51 PM
RocketyMan
Apr 27, 2014 09:22 PM
