Free ceramic coating - couldn't pass it up
Transmission: 4L80E/4L80E
I won a NHRA drawing for free ceramic coating last season. All I had to pay was shipping each way (which you have to pay normally, anyway). I hadn't heard of the outfit before, Swain Tech Coatings, but checking around, apparently they have a decent reputation.
I already had the headers for the LS1/T56 car coated by Jet Hot, but not the LS1/4L60E car, so I decided to use the certificate on them. I couldn't get to the job of getting the headers out until mid-March, and it took 5 days to get to them. They said 2-week turn-around when I talked to them on the phone back in December, when I talked to them after they received them, it was up to 3 weeks. Three weeks later, they said they were running a little behind, but should get them out by the end of the week. Turned into the next week, same story when I called them again, but at least they were in work by then, and they did ship by the end of that week. They arrived late last week (while I was out of town, of course).
Got them installed yesterday, got the car running today. The coating is thicker than I thought it would be - they had to mask off the collector (slip-fit), flange, and O2 bung threads. Only coated on the outside, but since they're made out of stainless, figured the heat being held in the tube walls wouldn't wouldn't cause strength issues (Jet Hot coated inside & out - Swain says nobody can really do that...). The coating seems pretty tough - I installed the passenger side first, tightened down the flange bolts, then realized I couldn't get the O2 sensor to screw in; so I pulled it back out again. I'm afraid the reinstall wasn't as clean as the original try, but no dings or flaking of the coating, even under the flange bolt heads.
Some pics:
Unpackaged:
Closeup of the tubes:
Installed, driver side (sure look different than Jet Hot):
Passenger side (I already grunged them up
I took it for a 7-mile drive tonight. The heat coming off them was greatly reduced. Not sure if it will translate to any differences at the track, but at least the O2 sensors should stay heated up.
Some pics:
Unpackaged:
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Free ceramic coating - couldn't pass it up
I'm definitely not a fan of that Milk Of Magnesia color, but if they function well I guess that's what matters!
Car: '91 TA vert
Engine: turboLSx
I've heard some really good things about SwainTech stuff. Looks good.
Car: 91 Firebird
Engine: 6.0
I'm a function over form guy, so the look doesn't bother me too much.
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
I'm just curious as to how much it was to have jet coat your headers
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I paid $235 from Jethot last year with shipping when they were having a sale.
Car: 86 Camaro Z28
is that inside too? they look great. I'm about to order a set of stainless works for my LT1. they offer coating but it's $450, and they're sent somewhere else to have it done. I'm not sure where to.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
