Firebird 89 ls1 prob with tach
Old May 6, 2012 | 03:35 PM
Christofbody's Avatar
Car: Firebird 89
Engine: Ls1 corvette 03
Problem with tach on a 89 firebird ls1
Hello I have a problem with my tach on my 89 firebird with ls1 engine. I bought the car and the previous owner had installed an aftermarket tach and 5 inch tach with tach adapter model 9117. The original cluster is also connected to the tach adapt. In short, my problem is that when I presses on the accelerator, my original cluster drops to 0 and when I release the throttle it goes back to the rpm of the aftermarket tach. Is that the problem is someone has already happened. thank you
Old May 6, 2012 | 11:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Firebird 89 ls1 prob with tach
Welcome aboard thirdgen.org.
I moved this to the engine swap subforum for LS swaps.
Sounds like you need the signal boost mod (or whatever it's called). Basically tap a switched 12v source, put a resistor in it to the tach output from the PCM to give it more voltage to drive the stock tach. https://www.thirdgen.org/forums/ltx-...ch-issues.html
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
