steel for notching frame
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
what thickness did anybody use to notch their frame for the A/C compressor.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: steel for notching frame
The piece you cut out, can't you just flip it & weld it back in upside down to fill the hole you created.
Transmission: 4L80E/4L80E
Yes, but then you'd still have holes at the ends.
The crossmember is 1/8". I got a piece of 2" x 3' 1/8" strap from Ace and used that to fill in the notch.
Car: 86 Camaro Z28
I feel that it'll look cleaner by not reusing that peice. Thanks for the thickness
Car: GTA
Modded with new steel.
Car: 86 Camaro Z28
Thank you for the help. Good pics. Mine doesn't need to be as big. It's for an LT1 lol
Car: 86 Camaro Z28
I dented it in at first, but It looked way too close. I have the engine back out, so I figured why not do it while it's out.
Car: 86 Camaro Z28
3rdgenparts
May 21, 2016 11:50 PM
darwinprice
17
Oct 11, 2015 11:51 PM
