LT1 Third gen rad problem
Old Aug 3, 2012 | 03:11 PM
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
I've read on the forums that you can "T" the line from the steam pipe with the overflow and run one hose into the top of the rad. My problem is the overflow fills up and spills over and the radiator empties. The rad cap is not allowing fluid into the radiator. How would I get around this problem? Thanks.
Old Aug 3, 2012 | 05:34 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
Re: LT1 Third gen rad problem
dont t it. get a 94 camaro upper hose and run the steam pipe there. no more problem.
Old Aug 3, 2012 | 06:34 PM
thunder57's Avatar
Car: 1987 IROC
I already got a 94 Corvette lower rad hose, would it be okay to T the steam pipe into the return line for the heater core?
Old Aug 3, 2012 | 06:38 PM
thunder57's Avatar
Car: 1987 IROC
I just looked up the hose you mentioned, I'll have to see if I can find it from a local supplier. Thanks.
Old Aug 3, 2012 | 07:59 PM
72vega's Avatar
i was gonna say when did i mention a 94 corvette lower?
midge54
Dec 27, 2019 04:14 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
