Quicky LS1 swap
Old Aug 18, 2012 | 12:40 PM
trigger GTA's Avatar
Car: 92 TA vert
Quicky LS1 swap
welcome to operation drop top swap.
this should be a fast swap. my plans are to remove the ls1 that has been in my 89 GTA for the last 8 years. give it a freshening up and reinstall it in my new 92 convertible. i am also going to swap tranys and rear ends
pic of both cars before the swap
last month i picked up a nice 92 convertible in Miami and drove it back here. the car has 45000 miles and is all original.
so the swap... this out of my 89
back in to the new convertible
Old Aug 18, 2012 | 03:49 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: Quicky LS1 swap
Oh man, that really makes you realize how much of an abomination it looks under the hood with TBI....
Old Aug 18, 2012 | 09:12 PM
Car: 92 TA vert
Re: Quicky LS1 swap
yep.
i was going to wait untill the winter to do this swap but the drive back with it was all i could take.
Old Aug 18, 2012 | 09:17 PM
Car: 92 TA vert
Re: Quicky LS1 swap
pics of the ls1 being dropped out of the car. took me the better part of the day. i also transplanted the suspention and kmember from the GTA
Old Aug 18, 2012 | 09:24 PM
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Re: Quicky LS1 swap
What are the plans going to be to freshen up the motor?
Also, just out of curiousity, what are the plans for the 89 your taking the ls1 out of?
Looks like its going to be fun
Old Aug 18, 2012 | 09:41 PM
Car: 92 TA vert
Re: Quicky LS1 swap
heads, cam, gaskets
selling the GTA off as a roller. his plans are a carbed 383
Old Aug 18, 2012 | 11:44 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Quicky LS1 swap
You are opposite from me, I hate verts, but t tops is in between, I would rather have the GTA. Lol
Old Aug 19, 2012 | 12:07 AM
Car: 92 TA vert
Re: Quicky LS1 swap
i have had them all at one point. 3 t tops, many hard tops, but this is my first vert. thought it was time for somthing different. i only got 1400miles on it before the swap and almost all of them were in 2 days bring it back home lol so i am still undesided about it.
Old Aug 20, 2012 | 10:42 PM
Car: 92 TA vert
Re: Quicky LS1 swap
pics of the TBI coming out of the vert.
Old Aug 20, 2012 | 10:47 PM
Roccos 89 IROC's Avatar
Re: Quicky LS1 swap
THE T TOP IS SO MUCH SEXIER LOL
Old Aug 20, 2012 | 11:00 PM
haisud's Avatar
Re: Quicky LS1 swap
+1
Old Aug 21, 2012 | 03:53 PM
BADNBLK's Avatar
COTM Editor
Re: Quicky LS1 swap
Cool swap man!
Old Aug 21, 2012 | 06:36 PM
Car: 92 TA vert
Re: Quicky LS1 swap
ouch... thinking i should have started this post in the vert section
Old Aug 21, 2012 | 06:49 PM
Car: 92 TA vert
Re: Quicky LS1 swap
last job to be one once the gta was on the trailer was to pull the K member. i kept this one because it was all sand blasted and painted nice from the first swap
next step. prep the bay for paint
Old Aug 22, 2012 | 03:29 AM
haisud's Avatar
Re: Quicky LS1 swap
What oil pan you use?
Old Aug 22, 2012 | 09:06 PM
Car: 92 TA vert
Re: Quicky LS1 swap
just the stock one
Old Aug 26, 2012 | 06:02 PM
Car: 92 TA vert
Re: Quicky LS1 swap
pics of the engine bay after paint
Old Aug 26, 2012 | 06:07 PM
Car: 92 TA vert
Re: Quicky LS1 swap
while it was at the painters there was some free time to tinker with the engine
added a lunati 232/232 .600 lift cam and a set of 706 heads that were ported and bench flow tested to be equal to AFR number
Old Aug 26, 2012 | 10:11 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Transmission: 4L60E 3,200 Edge stall
Axle/Gears: 9 bolt w/3.90
Re: Quicky LS1 swap
Out with the GTA and in with the vert, ouch. But then I'm partial. Good luck anyway and nice job so far.
Old Aug 28, 2012 | 11:02 PM
Car: 92 TA vert
Re: Quicky LS1 swap
lol seems to be the trend
forgot to add pics of the old cam and its dammage. i think the springs were weak and the lifter might have been bouncing
Old Aug 29, 2012 | 06:33 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Quicky LS1 swap
Dang, that is crazy.
Old Aug 29, 2012 | 06:30 PM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Re: Quicky LS1 swap
Man, that is pretty crazy!
Old Aug 29, 2012 | 07:57 PM
Car: 92 TA vert
Re: Quicky LS1 swap
i was very suprised to see that damage. Ended up costing me a new set of lifters also.
pics of the rear end swap. i took it from the GTA also for a few reasons. better gears, posi, and disk brakes.
The under side of the car looks very good and clean.
The vert fuel sending unit was not working and i needed my walbro255 pump from the gta so dropped the tank down at the same time.
found out why the car was running so bad and why the sending unit was not working. the tank was full of rust and the fuel had turned to jelly. one of the disadvantages of buy a low mile car.
Old Aug 29, 2012 | 08:02 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Quicky LS1 swap
Nice work, its refreshing to see a build thread that actually is going somewhere.
Old Aug 31, 2012 | 09:04 PM
Car: 92 TA vert
Re: Quicky LS1 swap
thank you.
thats also why i called it quick swap. it really helps when its a stright swap and everything has been already figured out.
the LS1 is now sitting in its new home. all bolted in and waiting for wires
Old Aug 31, 2012 | 09:20 PM
Car: 1985 IROC-Z
Engine: 355
Re: Quicky LS1 swap
Looking good man! Quick or not so many threads started by dreamers that never get started or finished.
Old Sep 1, 2012 | 10:03 PM
Car: 92 TA vert
Re: Quicky LS1 swap
now that part every one loves... wires
my harness was already modded for the 89 and i wanted to just pull out the hole thing starting from c100 but it turned out that they are not the same pin out. sooo i had to strip out all the old TBI wires and only kept the few that was needed for the ls1. i did manage to catch a small brake in the fact that the 92tbi also uses a signal box for speed like the older GTA and also that C207 were the same for both so it was just a mater of plugging it in.
Old Sep 2, 2012 | 03:19 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Quicky LS1 swap
Blah, the worst part of messing with a LS or LT swap....carbed or not, alotta wires have to come out.
Old Sep 4, 2012 | 04:02 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Quicky LS1 swap
Are you keeping the 15" firebird sleeper wheels, or using the 16" GTA PW7 wheels? If you are using the GTA axle, you'll want to use the GTA wheels, also because of the special rear disc offset.
This swap must be pie compared to the first one.
Old Sep 4, 2012 | 05:05 PM
Car: 92 TA vert
Re: Quicky LS1 swap
yes this swap is much easier. almost every thing is already figured out. just moving alot of parts from one car to the other.
but i did still run into some issuse with the new header fitment.
both axls are the same size and both set of rims fit no problem
i plan to use my vette rims shown here
Old Sep 4, 2012 | 05:23 PM
Car: 92 TA vert
Re: Quicky LS1 swap
head cam and headers were the only changes i made from the last set up. here are the headers
the fitment was not good but they were never intended to still have a 700r4 in there i guess. i had to cut a flange on each side to make room. i also had to relocate the trany mounting braket because it was in line with the collector.
the biggest anoyance was the collector was hitting the outside frame of the car on the passenger side. After talking with Hawks about it they said to strap the header over and when i weld up the Y pipe let it hold the header is place. Or option 2 was to unbolt every thing and see if i can get the engine shifted in the car just a little bit to get it off the frame.
Old Sep 4, 2012 | 05:42 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: Quicky LS1 swap
Yea, cannot wait to see how the fit with my th400.
Old Sep 4, 2012 | 09:22 PM
Car: 92 TA vert
Re: Quicky LS1 swap
what size headers and collector did you get? also what does your trany support look like? with the 700r4 cross member there was no way to go past it other then dropping down
Old Sep 4, 2012 | 09:59 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: Quicky LS1 swap
look like the 1 5/8 and 2.5" collector
Old Sep 5, 2012 | 09:02 PM
Car: 92 TA vert
Re: Quicky LS1 swap
3 in collector
Old Sep 5, 2012 | 09:22 PM
Car: 92 TA vert
Re: Quicky LS1 swap
some more updates. almost every thing is back in. Last big job was to extend the computer into the stock location. in the old gta it was where the A/C and blower fan was. This time its something i wanted to keep.
Old Sep 5, 2012 | 10:11 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Re: Quicky LS1 swap
Very cool swap, while I'm partial to hard top GTAs, if you have been there done that, no reason not to try something new. Definitely, faster the second time around, I know if I ever do another it will be way faster, and done better (I hope, so many things to do differently....). Wish I had a hanger to do it in though....
Old Sep 5, 2012 | 10:28 PM
dprest68's Avatar
Engine: cammed LS1
Re: Quicky LS1 swap
Are those butt connectors that you used to extend the harness? Man, I caught all kinds of crap for using them on mine... and they were only temporary until I got a better soldering gun!
Old Sep 6, 2012 | 06:00 AM
Car: 92 TA vert
Re: Quicky LS1 swap
they are not exactly butt splices. they are far better then butt or soldering.
its what is used to splice wires in aircraft. they have a crimp part and an jacket that wonce heated seals the splice from weather
Old Sep 6, 2012 | 08:41 AM
dprest68's Avatar
Engine: cammed LS1
Re: Quicky LS1 swap
Ah, cool. Sounds like you should be good to go then. Your swap is coming along nicely.
Old Sep 7, 2012 | 09:21 PM
Car: 92 TA vert
Re: Quicky LS1 swap
well for the most part is done.
here are few pics of the end results and a short vid with open headers
Old Sep 7, 2012 | 09:39 PM
  #42
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Quicky LS1 swap
nice swap man, I loove the drop-top!
Old Sep 13, 2012 | 08:06 PM
  #43
Car: 92 TA vert
Re: Quicky LS1 swap
the car has now been to the exhaust shop and is back. all i can say is i am not to happy with the end results. because the 700r4 mount is stright across the exhause had to dip under it. Now its just far to low for me. so i am now looking for a t56 to swap in. in the mean time i will have to put the stock spring back in to help give me more clearance. but intil i get that done i did take a few finished pics.
Old Sep 13, 2012 | 08:24 PM
  #44
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Re: Quicky LS1 swap
I think either Hawk's or Spohn makes a crossmember with a double hump in it to give room for the exhaust. Maybe look there before swapping transmissions? A custom y-pipe may suit your needs to, like this one that needed a special trick to go with it too.
Attached Thumbnails Quicky LS1 swap-2012-02-16-16.56.52.jpg   Quicky LS1 swap-2012-02-01-21.09.18.jpg   Quicky LS1 swap-y-surprised.jpg
Old Sep 13, 2012 | 08:30 PM
  #45
Car: 92 TA vert
Re: Quicky LS1 swap
the crossmembers your talking about are only for the 4th gen tranys. i have not seen any for a 700. but thats ok the t56 is was my final goal is anyways. i looked at making my own for the 700 but i felt there would still not be enough room for 3inch pipe
Old Sep 13, 2012 | 08:43 PM
  #46
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Re: Quicky LS1 swap
gotchya. go for it then!
Old Sep 14, 2012 | 07:15 PM
  #47
V6canvas's Avatar
Engine: Stock LS1
Re: Quicky LS1 swap
Do a little research on the double hump k-member, I was looking at that wishing I had it (it came out after my swap was done). But it seemed people were having issues with the bolt holes lining up. It may be easier to just fab your our. Though I will always encourage a t56 swap!! My k member it sphon's t56 swap piece, and my y-pipe looks a lot like yours, really kills the ground clearance. The bottom of both sides are now flat due to scraping bottom.
Old Sep 14, 2012 | 08:08 PM
  #48
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
Re: Quicky LS1 swap
great job on the swap, especially in such short of time. As for the exhaust, it could be worse lol Mine is even worse.
Old Sep 14, 2012 | 08:23 PM
  #49
Car: 92 TA vert
Re: Quicky LS1 swap
thanks guys for all your complements
pearl iroc OMG did you have to cut your bump stops to have suspention travel! how much clearance do you have there? even on your oil pan looks low
Old Sep 14, 2012 | 08:31 PM
  #50
irocdls1's Avatar
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
Re: Quicky LS1 swap
so you used the 700r4 what you need to attach it to the motor and what passing gear cable did you use....
