Ford 30lb "redtop'' injectors,multiple part numbers??
Old Oct 29, 2012 | 04:53 PM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
Not sure if im posting this thread in the correct forum or not..but,i just purchased a set of 8 used ''red top'' 30lb injectors off ebay for my LT1 and they all look identical but upon checking that all the part numbers matched,i found i have (5) part # 0-280-150-945,..(2) part # 0-280-150-756, and (1) part # 0-280-150-911,ive checked all three part numbers and i get conflicting specs from various sites,can anybody tell me if these injectors are compatible or not??,
Old Oct 29, 2012 | 05:02 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Ford 30lb "redtop'' injectors,multiple part numbers??
They should all be rated 30#/hr @ 39.5 psi
Do they physically look the same?
Old Oct 29, 2012 | 05:12 PM
LT1IROC-Z's Avatar
Car: 87 IROC
Engine: LQ9 6.0
yeah,they all look identical,just the part numbers are different and so are the numbers on the other side of the injectors,just wanna make sure the all flow the same because i ran all the part numbers just to be safe and i kept getting different specs for each part number ranging from 28.55lb/hr to 32lb/hr but all the specs vary from site to site so i cant find a definate answer.
1992 Trans Am
May 10, 2023 07:19 PM
twest2k2
Aug 24, 2015 11:26 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
