SES light on after 5 sec along with both fans
Old Nov 23, 2012 | 05:41 AM
shone190's Avatar
Hi guys,
I have a problem with LT1 engine swap (from 1993 Camaro into 1988 GTA). Problem is when I start the engine, after 5 seconds SES light is on along with both fans. When I try to check codes (with engine off), there is only code 12 that shows everything is OK
Is there a chance to check codes while engine is on, because only then I have SES light on?
I think that problem is because I don't have A/C at all, so maybe PCM think that A/C pressure is too high and turn both fans on, that's just my opinion
So, how can I found what trigger SES light and fans?
Old Nov 26, 2012 | 09:44 PM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
Re: SES light on after 5 sec along with both fans
hopefully you know how to use a multimeter, if so check these wires at the PCM connectors these should all have either open or high resistance, D24 Evaporator temp, D12 AC Pressure Sensor, C25 Engine Collant Temp Sensor, . then check these system grounds for a 0 resistance to ground A2, C32, A18, D1. LET US KNOW
eightsixseven
Dec 16, 2024 01:50 PM
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Omega
Aug 10, 2015 12:46 PM
