Rebuilding/porting my LT1 heads, need advive on good hardware!!
Old Dec 5, 2012 | 02:35 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys, I'm finally getting my LT based 383 for my 88 and I need advice on getting some good hardware for them. I'm having the heads opened up to 2.02/1.60 and what would be a good valve set to use? Plus I lost ALL of the stock valve shims for the heads, where can I find new stock replacements? any advice on a good spring set? I'm thinking about running either of these 2 Lloyd Elliot cams with the Edge 3200 stall that I already have.
232/240 .578/.574 110 LSA - 2200-6400 RPM
236/244 .579/.578 110 LSA - 2400-6600 RPM
Any help on this would be awesome and I'm in a big rush to finally get this motor done.
Old Dec 7, 2012 | 05:23 PM
Re: Rebuilding/porting my LT1 heads, need advive on good hardware!!
Anybody? a little help here lol
Old Dec 7, 2012 | 06:35 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
Whoever does your valve job would have shims. And they would use the correct amount to set the seat pressure for the given cam.
Old Dec 7, 2012 | 06:55 PM
DIGGLER's Avatar
you wont be able to use any of the stock stuff anyways. youll need new springs, retainers, locators, and shims. you will need to machine the spring seat areas for added clearance for the springs, as well.
Old Dec 15, 2012 | 01:25 PM
I'm aware of that,lol. I was just wondering what would be a good hardware set for the cam(s) I'd want to use.
Old Dec 29, 2012 | 01:42 PM
Ok here's my next question, I found these on ebay from a seller I've dealt with before with good results. Has anyone here used these valves?
http://www.ebay.com/itm/200831768315...84.m1423.l2649
Also, would this kit work well in my application?
http://www.ebay.com/itm/390514415741...84.m1423.l2649
Some help here would be great guys....
LilHot
South Central
Apr 13, 2026 11:46 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
