Swap Mount Instructions
Old Dec 6, 2012 | 05:26 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
http://www.hawksthirdgenparts.com/pr..._90549_std.jpg
Are these supossed to come with instructions?? The holes dont line up at all????
Old Dec 6, 2012 | 05:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Mine did.
Call them up and have them email you a .pdf of them.
Some of the holes line up, you need to drill others.
Old Dec 6, 2012 | 09:40 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: Swap Mount Instructions
The drivers side I had all 4 line up, the passenger side only had 3 line up and I had to drill one hole. My car was a v6 car to start. I tossed my instructions, but IIRC, it's pretty much line up the forward facing holes of the adapter plates, to the rearward holes used on the kmember for the factory clamshells. There were no illustrations.....
Old Dec 7, 2012 | 05:07 PM
Pocket's Avatar
Car: 91 Trans Am
^ Thats how you do it
Id suggest fabbing a "nut plate" with some scrap sheet metal and some nuts welded to it since the K-member nuts are a huge pain to access
Old Dec 8, 2012 | 08:27 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
thanks, I was thinking I was gonna have to take a holesaw to the Crossmember to access the nut! Ive got them in place.
Now I have to figure out with the Hawks Trans Crossmember if the fuel/brake lines get pushed up on top of the crossmember or on the inside edge???
Old Dec 10, 2012 | 02:11 AM
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
I'd Secure it to the back end of the Kmember, It doesn't have much room but that's how the mounts are made.
Old Dec 10, 2012 | 05:28 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
??? Not sure I follow???
Old Dec 10, 2012 | 06:02 PM
Axle/Gears: 4.10
The brake lines, I'd use some metal clips or something to secure it to the back part of the k-member. The fuel lines should come up the driver's side frame rail so you shouldn't be worried about those.
Old Dec 11, 2012 | 10:06 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Gotcha. Where I am concerned it where the fuel lines run through the tunnel. With the Hawks trans crossmember it interferes with the factory routing. I'm thinking it would be more safe to just bend the lines to go over the crossmember rather than let them be on the exhaust side of the crossmember. Either way it looks to be the factory routing is out the door.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
