Can I use a different 3rd Gen Harness to Start My LQ9 Wiring?
Subscribe
May 25, 2013 | 09:18 AM
I'm currently in the process of building an lq9 for my 83 trans am and I'd like to get started on the wiring. What I'd like to do is buy another 3rd gen harness to work with so I can keep driving my bird around. I would think this is possible since you're cutting out the majority of the wiring anyway but I'd like to make sure. Thanks!
Reply 0
May 25, 2013 | 11:12 AM
Re: Can I use a different 3rd Gen Harness to Start My LQ9 Wiring?
you could, but remember that the c207 and c100 can change from year to year and engine to engine. I *highly* recommend getting a service manual for your specific model. that way you can repin the second harness to the setup in your vehicle.
Reply 0
May 25, 2013 | 01:46 PM
Any 82-84 harness should work no problem. If you're ok with repinning a few things and adding a few extra connectors, any 82-92 harness will work
The latter requires a broader knowledge for interchanges
Reply 0
May 27, 2013 | 08:30 AM
Quote: Any 82-84 harness should work no problem. If you're ok with repinning a few things and adding a few extra connectors, any 82-92 harness will work
I don't have a problem with this. You should have seen what I had to do to a vw CAN-BUS harness to make it work with a 81 rabbit. I just need the right wiring diagram.
Thanks guys
Reply 0
Subscribe
