lt1 won't run with maf sensor
Old Sep 28, 2013 | 04:30 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
My car is finally running good. Except it won't run with a maf sensor hooked up.I tried my friends maf sensor and will just die. Also after 15 minutes it will start to run terrible. After warm up. I think its running rich
Old Sep 28, 2013 | 07:36 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: lt1 won't run with maf sensor
This is a bit hard to understand, i would say that if it dies with the maf installed buy a new one. your friends maf does the same thing and it's in working condition? I would check the codes and buy a brand new maf, if that don't work i would buy a new opti just to have one in stock. You never know when you'll need it.
Old Sep 28, 2013 | 08:29 PM
jaysfs's Avatar
Transmission: t56
I have two spare good optis. Alittle silly I know.yea his came off a running ta and mine is brand new. I only have one code and that's when tye maf is unplugged
Old Sep 28, 2013 | 08:43 PM
89rs454's Avatar
Car: 1989 SS
Sorry man, i honesty don't know if you find out what it is the post it here.
Old Sep 28, 2013 | 09:44 PM
jaysfs's Avatar
Transmission: t56
I will .I have a good mechanic tryin to help me out.as soon as this lt1 runs right I'm throwin the rearend in.My 3.70 has been sitting in the corner waiting
Old Sep 28, 2013 | 09:52 PM
mygta87's Avatar
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
On my tpi engine I had the same problem and it was due to my fuel regulator it wasnt regulated to exact psi so after that it idle with maf on though.
midge54
Dec 27, 2019 04:14 PM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
