LSX swap question about ECU location
Old Oct 14, 2013 | 03:51 AM
No4Play's Avatar
Car: 1992 RS Heritage Edition
Engine: LS6 Mut
Axle/Gears: Stock
Ok people of TGO, I have a question. For those of you who have done an LS swap on your third gens, where are you locating your computers? I thought about removing the coolant reservoir tank and putting it there then getting a sweet looking aluminum reservoir to put by the radiator. My predicament even though I'm doing a swap, I would like to keep the engine bay accessories as factory as possible. I am using a factory 2002 camaro harness and computer.
So...where a how have some of you all located your computers? Is it too much of a headache to put it were the factory 92 ECU's were located? any wire extending required? is there a good place to tuck the computer without moving too much out of place and not having to extend wiring?
Thanks in advance for your replies!
Darryl
Old Oct 14, 2013 | 06:00 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: LSX swap question about ECU location
The cleanest PCM mounting location I believe is in stock thirdgen placement under the dash. Lengthening wiring becomes manditory to put the PCM here with factory routing. Some guys have drilled a hole under the thirdgen heater box in the firewall, and out the PCM under the dash without lengthening too much wiring. Personally not a fan of putting a large hole in the firewall, but it is an option.
Old Oct 14, 2013 | 06:17 AM
No4Play's Avatar
Engine: LS6 Mut
Axle/Gears: Stock
This is the direction I'm leaning toward. I have a hacked up 5.3 harness that I think I am going to rob wiring from that way the color codes match. Now I just have to figure out how to wire the cruise control in. I checked out the thread on how to do it and it seemed pretty straight forward.
Caspar
Jun 19, 2016 11:19 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
E Rod
Aug 28, 2015 05:17 AM
redmaroz
Aug 16, 2015 11:40 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
