LT1 swap speed density question
Old Oct 19, 2013 | 02:19 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Transmission: T5 manual
Im looking at a rebuilt 93 lt1 thats SD setup and i was wondering should i keep the SD or get the parts to switch over to MAF? not reall to familiar with SD. so was just wondering, all i plan to do is just have headers and exhaust mods that i have on my 350 tpi put on and thats all the mods i plan on for the lt1.
Old Oct 20, 2013 | 06:29 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: LT1 swap speed density question
FWIW.
The 92/93 ECM's have lots of well documented problems so if you were going to do anything your would upgrade to the 94/95 LT1 setup that has both MAP and MAF.
They run primarily on the MAF sensor with the MAP as a backup
Old Oct 20, 2013 | 12:12 PM
GreenieG's Avatar
Car: 1985 IROC-Z
what would i need to do that?
Old Oct 20, 2013 | 01:00 PM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Axle/Gears: 3.23 Australian 9 bolt
The intake is different, the MAP plugs right into it on the passenger side, also might need the fuel rail because the cross over is different but you might be able to make that work. And of coarse the MAF sensor and pig tail, and you can probably just pin out the harness yourself
Old Oct 20, 2013 | 04:45 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
No need to change the intake , just remote mount the MAP sensor like done on the TBI cars/ trucks
Old Oct 20, 2013 | 04:51 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
A 94/95 LT1 computer and wiring harness
There are adapters available to use the early Optispark with the late harness if required
http://www.eficonnection.com/eficonn...px?ItemId=1032
If you can prove your no longer available 92/93 ECM is good it can be worth some $$$ to offset the swap costs
midge54
Jan 29, 2017 07:00 PM
Steve78LT
Feb 24, 2016 12:15 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
86Base
Aug 8, 2015 01:34 PM
