ls swap wiring questions
Old Dec 29, 2013 | 07:49 PM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
1. Since I have a whole ls1 donor car would it be best just to trash all my thirdgen relays and use what's with ls1 car such as fuel pump relay,fans and etc..??
2. Looking at austinthirdgen.org diagrams it looks like I could bypass my vats by just grounding one side of the coil to the starter enable relay...does this seem correct?? Seems to simple
Old Dec 29, 2013 | 10:34 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: ls swap wiring questions
Thirdgen relays are more than adequate and there already there ..
Bypassing relay is just that easy ..
Old Dec 30, 2013 | 06:58 AM
Pocket's Avatar
Car: 91 Trans Am
The last part of the 3rd gen VATS is the starter relay and yes grounding it is that simple. The LS1 PCM still needs VATS tuned out still unless you move all the 4th gen stuff over including the IGN cyl
Old Dec 30, 2013 | 09:24 AM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
OK ..thanks for the help guys..
Old Jan 1, 2014 | 08:25 AM
bungy74's Avatar
Car: 1992 Camaro Z28
Engine: 5.0 TPI
Transmission: auto
I also had an entire donor car when i did my swap. I ended up using the stock 4th gen fuse/relay box under the hood. There are two on the 4th gen car i had, but i took them apart and made everything fit in one box. I have my fans and fuel pump fuses and relays in there, also have plenty of open slots for any miscellaneous fuses etc. There are many ways you could go about it, but having the entire donor car sure gives you alot more options. Good luck !
midge54
Sep 2, 2020 07:13 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
