ls swap power steering hose in 89 Formula
Old Mar 19, 2014 | 08:43 PM
formula89utah's Avatar
Car: 1989 Firebird Formula 350
Engine: LQ9/LS3 Heads
Axle/Gears: 3.27 9 bolt
I am using Corvette accessory brackets and power steering pump on my Ls swap.
Has anyone got some info on what is the best high pressure hose to use with this swap?
Old Mar 20, 2014 | 09:35 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: ls swap power steering hose in 89 Formula
Not what you are thinking of, but I used Braided line and -6 AN fittings. C5 LS1 in my car.
Old Mar 21, 2014 | 10:10 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Same here, bought a fitting from Detroit speed for the pump & built an AN hose.
Old Mar 22, 2014 | 07:23 AM
Flip 2's Avatar
Engine: C5 LS1
Got my fittings from Lee Manufacturing, in Sun Valley, CA. Cheap.
You want to use GOOD line. First one I had was from stuff I had sitting around. It did not hold :-(. Teflon line in there now.
Old Apr 4, 2014 | 08:35 PM
Thanks for the input. I used a 98 Blazer H/P hose and tweaked on the pump end to about 80 degrees and it fits like it was made for the car.
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
