Steam Ports?
Old May 11, 2014 | 06:54 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Steam Ports?
I've got a 91 z28 with a LS1. Im using the stock TPI radiator and still working out the many bugs. What did you guys do with the steam ports from the heads? I have a hose going from the steam ports an inlet on the passenger side of the radiator, toward the top, however the hoses I use leak, and it just isn't sound.
What is the proper way to do this?
Old May 11, 2014 | 10:05 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: Steam Ports?
I have heard of people tapping the water pump and running it to there.
Old May 12, 2014 | 10:36 AM
drduster's Avatar
Car: '88 Iroc-Z
Axle/Gears: 3.23 posi 10 bolt
Re: Steam Ports?
I was advised by Bruce Hawkins on this while visiting his place to buy parts. I don't have the specs on the fitting he gave me, but attached a picture of what it looks like. Apply epoxy to the threads of this fitting, thread it into the heater hose nipple on the third gen radiator & attach the stock LS1 steam hose. Below shows what it looks like installed on my car.
Attached Thumbnails Steam Ports?-0431668.jpg   Steam Ports?-img_0512.jpg   Steam Ports?-img_0515.jpg
Old May 12, 2014 | 02:58 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Re: Steam Ports?
http://www.jagsthatrun.com/Pages/Par...g_LSI-tee.html. This is what i used. Its easy and hell to set up.
Old May 12, 2014 | 04:51 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Steam Ports?
Whether it's threaded or not and thread size seems to vary from rad to rad. I've seen smooth, 1/4"NPT and 3/8"NPT
I use a common nipple like posted with some pipe tape on most. On the unthreaded ports I fab a union tee like the JTR link
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
