95 caprice harness swap questions
Old Jul 14, 2014 | 12:09 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
i had questions on the caprice harness, i read that there are only two wires needed to wire to fire the engine, like a stand alone harness and that everything else will still need wired ie gauges. Does anyone have experience with caprice harness, are they much different than an fbody harness. im trying to swap in a 95 caprice LT1/4L60E and harness
Old Jul 14, 2014 | 02:08 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 95 caprice harness swap questions
There is no easy solution using oem harnesses for any engine swap
Fbody vs bbody is totally different, but disassembly and rebuilding them takes the same route with just as good results
Do a search for lt1 harness start to finish
Old Jul 14, 2014 | 05:19 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
is there another thread that has the pictures to go with the write up
Old Jul 14, 2014 | 07:39 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
also go to ltxtech.com i bet alot more info there.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
