msd 2 step ls1 control switch?
Old Sep 30, 2014 | 05:55 AM
ls2 dude's Avatar
Car: 1989 iroc z
Engine: 98 ls1, prcs, btr cam
Transmission: rkt56 6 speed
Axle/Gears: midwest chassis 9 inch 4.30wavetrac
so the msd 2 step is a plug and play for ls1 cars using the factory clutch switch. so for us 3rd gen guys what did you do to use a clutch switch?
Old Sep 30, 2014 | 03:11 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: msd 2 step ls1 control switch?
should be same as far as clutch switch wiring depending on pedals and clutch switch used
should also look into this and does both and adds ability to safley no lift shift andits cheaper
n2mb
http://www.npcompleteperformance.com/
Old Sep 30, 2014 | 08:22 PM
ls2 dude's Avatar
Car: 1989 iroc z
my issue is i dont have the factory wire from the pcm for the clutch switch. ill have to make something work. that box looks nice but i have the msd 2 step already
Old Sep 30, 2014 | 09:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I put a switch on the top side of the clutch pedal.
Old Oct 1, 2014 | 03:42 AM
ls2 dude's Avatar
Car: 1989 iroc z
and just tap into the msd box with it?
Old Oct 2, 2014 | 10:33 AM
five7kid's Avatar
There are two trigger wires. One you connect to 12v when you want the 2-step activated, the other you connect to ground when you want the 2-step activated. You can only use one of them. I used the ground function - the switch would be open when the clutch was engaged, and connected to ground when the pedal was depressed.
BRoss99
Aug 10, 2025 05:08 PM
deracer
Apr 11, 2016 12:04 AM
The_Phoenix
Feb 4, 2016 07:10 AM
toronto formula
Nov 10, 2015 06:17 AM
overdriv
Aug 20, 2015 03:52 PM
