LT1 into 83 Camaro Emissions?????
Old Feb 4, 2015 | 08:49 AM
Strick1's Avatar
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
If I choose to eliminate the O2 sensors which the donor car had (95 Caprice) and loose the STFT and LTFT, how can I know what the fuel air mixture will be? Since the ECM won't know how to adjust the injectors to maintain that 14.7 to 1 mixture from idle all the way to WOT, how do you know what the A/F is? Will I only be in open loop and is that okay? Or should I just keep the fuel trim system in operation? Thanks guys.
Old Feb 4, 2015 | 09:06 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: LT1 into 83 Camaro Emissions?????
You won't know what the mixture is without a O2.
Old Feb 4, 2015 | 02:49 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Will it even run very long like that? Let's tie your ankles together and do a 5k. Keep the o2 sensors functional.
Old Feb 4, 2015 | 05:32 PM
Strick1's Avatar
Thanks guys. I'm trying to get everything straight before I send the ECM out for reprograming. I like the fuel trimming system and need to do a little more research.
Old Feb 4, 2015 | 06:57 PM
Car: 91 formula ws6
Transmission: 4l60E
You have the rear o2 sensors tuned out since it should have been equipped with 4. Those aren't needed to run, they just monitor catalytic converter efficiency.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
