'94 LT1 swap advice/help
Old Mar 26, 2015 | 04:32 PM
DukecityWarrior's Avatar
Car: 1987 Trans Am
Engine: TPI 5.0L
Hello, I have recently acquired a 94' LT1 T56 T/A and I am planning on putting the engine/trans/rear in my 87' T/A after this conversion I'm planning on doing a 4th gen dash swap.
My question is how does the wiring come into play between harnesses on the car, engine, ECM, interior? Would most of it be "plug and play"?
I'm thinking of doing custom 4th gen door panels as well so I would have switches in the door, and mentally attempting to have full functioning heat and AC. I know stock camaro/firebird LT1 has issues with position of AC compressor. Anyone have success using corvette LT1 AC bracket?
Anyone have experience in full conversions? Any tips or advice would be appreciated.
Old Apr 2, 2015 | 11:26 AM
Pocket's Avatar
Car: 91 Trans Am
Re: '94 LT1 swap advice/help
If you plan to swap the dash too, Id swap every wire from the donor over, column, cluster, all the interior you can grab
Old Apr 3, 2015 | 08:16 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Won't be much left to worry about.. Fuel pump.. fans if you're not swapping the 4th gen ones.. Some power and Gnds.. big project all at once though. I'd keep notes.
Old Apr 3, 2015 | 08:19 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
Corvette LT1 bracket works fine but you need the accessories and damper. Spacing off the block is different than Fbody.
Custom AC lines and notching of the kmember are required to use AC on Fbody acc. The customer lines are the hardest part.
If you're swapping dashes, I'm not sure how the blower/heater box with AC will swap. Likely not a huge issue.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
