What fuel pump do you guys recommend for a boosted car?
Old May 2, 2015 | 06:32 AM
Justin69's Avatar
Car: 89 Camaro RS
Engine: LT1 w/ 70mm Turbo
Transmission: Stage 3 TR6060
Axle/Gears: 4:10
I just found out I still have the stock fuel pump. It has an LT1 with a 70mm turbo/T56. I'll have rearend out this weekend and figure now is the time to do it.
I was looking at the Aeromotive Stealth pump. What do you guy's think? Also am I going to have to run all new lines ( Stock lines are still in it) and if so, what do you guys recommend. Car is a little over 500 hp. Future plans are a 383 stroker and more boost.
Thank you in advance.
Old May 2, 2015 | 07:25 PM
Westech's Avatar
Car: 1991 Camaro RS
Axle/Gears: 7.6" 3.73 yukon locker
Re: What fuel pump do you guys recommend for a boosted car?
Stock TPI pump will power 500 HP
Old May 2, 2015 | 09:32 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Walbro 255 would support 500hp but Im going to run a walbro 455 intank. I rather have more than i need for a pump than running a smaller pump very hard.
Old May 3, 2015 | 01:44 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Check out this website: http://www.autoperformanceengineerin...l/fpspecs.html
According to the equation on their FAQ page the Walbro High Pressure pump at 13.5 VDC and 60 psi will support 700+ HP. That is the pump in my car at this time and what I am going to continue to use in my conversion.
Old May 3, 2015 | 01:50 PM
Justin69's Avatar
Car: 89 Camaro RS
Axle/Gears: 4:10
Thanks guys. I do plan to add more power later. Have any of you used the Aeromotive 340 Stealth pump?
Old May 3, 2015 | 09:19 PM
Pocket's Avatar
Car: 91 Trans Am
I used the 340 pump, my best advice is to RUN AWAY FROM AEROMOTIVE 340's
Twin 255's are cheap, reliable and more than enough for your build. Boost reference the second via hobbs or run it continuous. Both methods work fine
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
