Ls1 4l60e drivetrain fitment
Old Aug 3, 2015 | 09:03 PM
Jman1993's Avatar
I'm sure someone has answer this but I have a 89 Camaro that I have a stock 99 ls1/4l60e and aluminum ds to go with and I just need to know what do I need to buy to get the motor and trans and everything to set in and line up as factory as possible I know to run ac I have to k member but that's about it!
Old Aug 5, 2015 | 06:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you want to use the factory AC compressor mounting position, you cannot use the adapter plates that use Gen I engine mounts. Meaning you need to get K-member swap mounts that use the 4th gen engine-side mounts.
You'll also need to get a swap tranny cross member. I like the Hawks for exhaust routing, but others work as well.
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dusterbd
Sep 29, 2015 08:40 AM
