lt1 swaps what cables??
Old Sep 10, 2015 | 08:06 PM
L0tuS's Avatar
I have a 90 firebird that had a tpi in it has lt1 with 700r4 now.what throttle cable and kick down cable did u use?and did you use the lt1 throttle bracket.I have the 93lt1 bracket that has the hole for a kick down. but my stock cables seem to long any one know what universal cables will fit?
Old Oct 3, 2015 | 09:19 PM
tnitz8787's Avatar
Car: 89 GTA/89 GTA
Engine: L98/lt1
Transmission: 700R4-
Axle/Gears: 3:27/3:73
Re: lt1 swaps what cables??
Your throttle cable should work, but you need the kickdown cable from a 93 lt1 f-body
Old Oct 4, 2015 | 08:07 AM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I'm using LT1 bracket and TPI cable.. They don't go together but I didn't have the LT1 cable. I had to weld the hole in the bracket a bit and cut it out to be square like the TPI end.. If you have the LT1 cable, then LT1 cable and bracket will work.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
timonator
Aug 13, 2015 11:27 PM
