LT1 timing marks
Old Dec 12, 2015 | 06:15 AM
rollbuck's Avatar
Car: 88 Pontiac Trans Am
Transmission: 700-R4
Axle/Gears: 373
LT1 timing marks
In process of installing 96 LT1 motor in 88 Trans Am. Motor had been converted to Edelbrock thunder carb and msd dist and box, and installed in 90 Camaro. Verified motor ran fine before removal. didn't think about external tdc mark somewhere before installation in 88. Nothing has been moved, assume motor will still run as before, but...I assume at some point it would be wise to check timing. New to msd, and this appears to be an older box, but does msd handle this? Have followed previous swap posts, but mine seems to be a little bit like everyone's, but no one in particlular.
Thanks for any help
Buck
Old Dec 13, 2015 | 09:37 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: LT1 timing marks
It does not have a timing mark as the balancer is not keyed to the crank.
I would suggest getting a piston stop & finding TDC so you know where it is.
Old Dec 14, 2015 | 01:58 AM
Twin_Turbo's Avatar
if it has angle plug heads don't forget to remove the exh rocker on cyl 1. You WILL bend the valve if you do not and wrestlke the crank past the interference.
LT1 cranks do have a keyway, JEGS offers a reasonably priced keyed damper/hub combo (ATI is really expensive) and it's indexed also. Might be a worthwhile upgrade.
Old Dec 14, 2015 | 07:30 PM
rollbuck's Avatar
Axle/Gears: 373
thanks to both. finally found that in another post.Will use piston stop, (couldn't get dial indicator with angle plug and headers installed. sure wish I thought about this with the engine on the stand.........just decided from beginning to leave the opti spark alone, with distributor already installed.
New to posting, but read all the posts on LT1 to gen 3 I could.
thanks again
stephen23648
Dec 19, 2015 09:10 AM
Rich1374670x
Nov 21, 2015 09:18 AM
kallark
Nov 15, 2015 08:51 PM
1985Z28LG4M5
Aftermarket Product Review
Nov 13, 2015 07:58 PM
