5.3 tight fit: Coil rubbing on passenger side
Old Mar 2, 2016 | 12:13 PM
ILMODC's Avatar
Before I get underway, big shout out to Pocket/Jon. Guy does amazing work and is a genius when it comes to our cars! He made me a custom C100 Harness to mate to my LS1 harness in my 1987 Trans Am. His prices are affordable and he delivers a professional product!
So I got an 5.3 with a GTO LS6 Intake manifold. I have truck coils and I have the #8 coil (if I recall) rubbing the HVAC black box against the firewall. I didn’t get a picture, but I had to unbolt the coil.
I’ve been searching and searching the forums and I recall special bracketry someone made where that single coil was up about 3 inches higher in the row. For the life of me, I cant seems to find anything.
All of the brackets I see when searching are relocation brackets of sorts that relocate the whole row.
Any suggestions out there? I saw someone bough some LT1 wires due to the extra length needed. Is there any single coil brackets that might work?
Old Mar 2, 2016 | 05:17 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: 5.3 tight fit: Coil rubbing on passenger side
It might have been mine that you remember.
https://www.thirdgen.org/forums/ltx-...ml#post5901869
Just give the welder the picture showing instructions, the bracket, one coil, and the valve cover. Can't go wrong if they have all the parts for fitment. It takes a pretty observant eye to even notice it was moved once installed in car.
Old Mar 3, 2016 | 09:33 AM
ILMODC's Avatar
Thank you Sir. Outstanding build by the way!
All the pics are blocked here at work, so I'll have to take a look at this post when I get home. I appreciate the insight!
Old Mar 5, 2016 | 09:43 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Thanks for the compliment!
Old Mar 7, 2016 | 12:39 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
I just relocated by last coil by midifying the stock bracket to raise and rotate the coil. You'll need a welder to do this one..
Old Mar 7, 2016 | 12:44 PM
ILMODC's Avatar
Slick. I like it. Did you have enough slack to run the stock spark plug wire?
Old Mar 7, 2016 | 01:11 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Yes, stock wire still works.
Anomaly
Jun 3, 2016 07:20 AM
seahawkfan
Feb 9, 2016 08:42 PM
hydrolic144
Jan 23, 2016 06:33 PM
JPMnLA
Jan 23, 2016 04:18 PM
florida_gators
Jan 15, 2016 08:36 AM
