OEM vs aftermarket Opti Spark
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
OK I need to replace the opti spark in my 87. It's out of a 92 vette . I see the OEM GM ones for about $150, the accel ones for $275. is it worth the extra money for the Accel? the engine is basically stock except for headers and a tune. Thanks pat
Transmission: T-5, TH350, T-5
I've found the aftermarket modules are terrible. Use a GM module. I have original 22 year old, 160k modules (ign and opti) working perfect while I've had 6 months and one year old aftermarket modules go south.
Engine: Lt1 in IROC
Re: OEM vs aftermarket Opti Spark
sounds good to me! I guess i should replace the water pump while i'm at it?
Why not? Water pumps for these are cheap compared to what they used to be. Though the water pumps themselves are reliable. Timing cover seals leaking are a problem though, might want to check those while you're there.
GCrites80s
Aug 15, 2016 05:33 PM
b2tw45p
Mar 10, 2016 01:57 PM
