98 Ls1 PCM pinout to kee A/C?
Old Oct 8, 2016 | 03:52 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
Do i leave all ac wires in tact to sensors except pin 47 AC REQUEST SIGNAL. im guessing that gets wired to factory hvac a/c wire?
will any sensors need to be cut or spliced with 3rd gen sensors?
Old Oct 9, 2016 | 12:22 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Re: 98 Ls1 PCM pinout to kee A/C?
Anybody?
Or anybody running a "stand alone" type ac system
Old Oct 10, 2016 | 06:44 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
You need a three pin high pressure sensor. 47 goes to the AC command from our HVAC, you can splice it in with the low pressure sensor on the filter dryer.
Old Oct 19, 2016 | 08:26 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Which wire from low pressure sensor?blue or green?
Old Oct 20, 2016 | 09:57 AM
Car: 92 Z28
Technically either works. If you use the blue you are still utilizing the cycling switch which is what is recommended. If for some reason you don't want to do that the green would send the AC command straight from the HVAC controls.
ndndndnd
Nov 1, 2016 08:47 AM
thejed72
Oct 8, 2016 05:08 PM
Ikes 91Z
Oct 6, 2016 03:09 PM
kevwalt22
Oct 5, 2016 07:01 PM
tchapps88
Oct 4, 2016 01:25 PM
