LS2 swap windage tray/oil pan issue
Old Oct 9, 2016 | 04:28 PM
Ryder85's Avatar
Car: 1985 Camaro Z28
Engine: LS2
Axle/Gears: 3:73
could use alittle help guys. im putting an ls2 in my 3rd gen. already have tubular k member. have what should be the correct oil pan, https://www.summitracing.com/parts/nal-12628771. i went with the windage tray hawks suggested, https://www.summitracing.com/parts/n...8253/overview/ .(pictured above) my issue is that this tray only has 3 nuts on each side. the oem has 4 nuts on each side. so this new tray leaves a gap in the front by the pickup tube. has anyone run into this? i also found this tray https://www.summitracing.com/parts/n...8189/overview/ . i think i can make the oem tray work if i notch out one of the nut locations where the new pickup bolts to.
thewizard
Mar 22, 2017 02:54 PM
armybyrd
Aug 26, 2016 12:39 PM
anesthes
Aug 25, 2016 08:58 AM
IROCU2
Aug 24, 2016 06:43 PM
