What's usable from 2001 LS1 SS
Old Oct 20, 2016 | 09:43 AM
z28yourstang's Avatar
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
Okay so I was gonna do a 383 with AFR heads and 700r4. Well this weekend I wrapped my daily driver 2001 SS around a telephone pole and broke my neck. My car is totaled but my 86 Z28 is awaiting a new engine so I wanted to merge the two cars together. So what all is usable from a 2001 LS1/4l60e that can be swapped into an 86. I'm asking if the fuel tank, gauge cluster and what else would be usable. I know I could buy everything from hawks but I have a complete downer car so only wanna buy what has to be bought. The SS had long tubes so I know I'll be buying their headers and I'm keeping a/c so possibly their conversion k member as well. Any help would be greatly appreciated. SS had 87,000 miles on engine and transmission.
Attached is a picture of both my cars
Old Oct 20, 2016 | 09:49 AM
Car: 1986 z28
Engine: 350 hsr
Re: What's usable from 2001 LS1 SS
Please no negative comments you guys don't know how ****ing stupid I feel already for recking my SS. I just put a GMMG exhaust on it which will be going towards the Z28. Don't ask how it happened because I really don't know, all I know is that when I woke up from a week long coma they told me I had recked my car.
Old Nov 20, 2016 | 09:41 AM
need4speed069's Avatar
Fuel tank
brake master
fuel piping
rear end Hopefully its posi
front spindles/ brakes
emergency brakes all of it
center console
radiator and fans
steering column
All the ABS , you can install it or sell it
All the wiring (all of it) at some point it time you will be glad you did
Old Nov 20, 2016 | 01:19 PM
Car: 1986 z28
Engine: 350 hsr
Originally Posted by need4speed069
Fuel tank
brake master
fuel piping
center console
radiator and fans
steering column
Pretty sure fuel tank and rearend are toast as well as the E-brake cables. I have a few questions...
If I swap the steering column into the car will I be able to add the cruise control and delayed wipers? My 86 has neither of those and they are the few amenities I'll miss from the car. Are there any benefits to running the 4th gen brake master? Or is it just suggested when running 4th gen calipers?
Old Nov 20, 2016 | 04:02 PM
Since I am using all the 4Th gen brakes on my car I decided to use the brake master and booster as well. As far as the wipers I havn't got there yet. But I used the E-brakes and center console from the 6 Speed.
