Heard of FiTech?
Transmission: 4L80E/4L80E
Heard of FiTech?
My son is putting together an LS1/TH400 swap for a '75 Vega using parts we had left over from previous projects. We didn't have PCM/harness/injectors, so he started looking into various options and came across this:
https://fitechefi.com/product-catego.../ls-induction/
I haven't heard them mentioned here. Apparently they've been doing self-tuning engine control and throttle body systems for awhile, and now are doing LS stuff. He said he hasn't heard anything negative said about them in his searches. He would go for the 500 HP/no trans control version.
We have HP Tuners, but aren't very proficient with it yet. He's using an MS3 cam and was going to have them send him a tune (he's done that in the past with his previous S10/LS1 clone project). This would solve a lot of issues if it does what they claim it does.
I'm not all that happy with the tune on my stroked LQ4/L92 heads/4L80E in my '57, and I'm making plans in my head for an upgrade to the LS1/4L60E in the Berlinetta. Just may consider going this route if it works out for him.
If you're starting out with no PCM/harness, or a truck engine, want to do upgrades to it (cam, heads, exhaust, injectors, etc.), and want to avoid the cost of HP Tuners or a dyno tune session, this may be a cost-effective way to go.
If it does what they say it does...
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Heard of FiTech?
I'm guessing he used the throttle body setup.
I only know of 2 vehicles running the LS system they introduced late last year. One is there test car 2nd gen TA. The other is a LS swapped S10 drift truck. The owner of the S10 is very happy with the system and how well it tuned itself and is planning on using it on other projects. Having talked with the team from FiTech at some SoCal events, they are a nice group of guys and appear to have solid well test products.
That's encouraging. Consistent with what my son has found.
Might be saving up my nickels and dimes...
Car: 1988 Iroc-Z
He's not to that point in his project yet.
Checked Summitracing.com today, says "Ships 06/02/17 if ordered today". Their website says, "Coming Soon". Seems to be a moving target.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Yes. They have a solid history of 'moving target' shipping. Their throttle body systems got way back ordered last year. I was in no hurry and not persistent in my follow ups with Summit (or Jeg's?) and eventually received my March order in July.
However if this LS system matches the quality and economy of their throttle body system, you'll be happy.
Jegs says, "No ETA".
I know all too well how planned delivery dates can go. I'm assuming they either have supplier issues, or have some bugs to work out.
I had heard on a Trifive forum that they have had harness issues. However, on that same forum, a member chronicled his issues with a GM LS3 525HP system that turned out to be a harness issue. And, who knows on these internet gripe sessions how much of peoples' problems were self-induced.
Guess we'll keep an eye on them.
Have a friend that just put one on his 400 SBC in his truck. It is modified (cam, hydro roller, etc) and he hadn't been able to tune a carb to make it run right (he lives across the state from me) and I suggested this. He is VERY happy. Says it runs amazing and was easy to install.
GD
GD
Car: 87 iroc-z
Engine: 454
Transmission: th350
would he consider going with a carb intake for the LS? then you could use the throttle body unit. edelbrock has a kit with the timing control for the coils; https://www.summitracing.com/parts/e...e2-_-edelbrock
just a thought.
just a thought.
just a thought.
just a thought.
I was actually thinking of the possibility of carb intake/TB system for my engine. I have plenty of hood clearance. But, again, it would cost more, and even more so since I would want transmission control as well (not an issue for him with a TH400).
Guess I should update this thread. I actually bit the bullet this spring and got the 750 HP rectangular system for the stroked 6.0 in my '57 Chevy with 4L80E. I had the factory 2003 PCM tuned to E85 with a HiRam, and was getting tired of the E85 hassle (mostly because I was considering running the Rocky Mountain Race Week, and E85 availability wasn't assured - and my windshield wiper motor won't fit with the HiRam...). The FITech Ultimate LS system seemed like a reasonable alternative to $500 each dyno sessions that didn't do anything for cold starts or driveability.
It did take a while to get it to settle in, but it eventually started producing numbers that equaled the E85/HiRam setup. And, cold start was worlds better, and driveability was much improved. In the process I did learn to stay away from E3 spark plugs (the primary reason for it being slow to settle in).
Summary: I think this system is a very reasonable choice, especially like I said in the original post when you're starting with a take-out engine (or parts laying around like my son did). It'll also handle cam and exhaust upgrades with no hiccups or tuning expense. The 750 HP versions have dual wideband O2 (500 HP single wideband - but I believe you can add a 2nd if you like). It is available with or without electronic trans control, and can handle 24x or 58x with a simple menu choice. You don't need a laptop or expensive interface/software to tune or data log (you do need to download the data file to a computer via USB connection to read it). The harness/PCM/hand-held tuner is also available separately if you want to use your own intake/TB/injectors/etc.
Also, I mentioned my son's Vega project. It actually is probably closer to the 3rd gen situation than my shoebox (for instance, it fit under the stock Vega hood). He did also use the FITech retrofit fuel pump system. He got it running in late September, drove it on the street for a day, went to a Wednesday test & tune session where it repeated within 2 hundredths in 3 runs (amazing for a low-prep "take-it-to-the-track" night), then took it to a points race on Friday and won the thing (8 rounds to win). On Sunday he took it out again for a Fall series race, won a Wally in a "Top Performer Invitational" race from the summer series, and runnered-up in the Pro class (tranny brakes allowed, he was footbraking).
So, do I endorse the system? You bet I do! {This has been a non-paid endorsement.}
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
This is good to hear. I bought the same 750 EFI kit for my LS swap this past summer but haven’t installed everything yet. The only bad thing I’ve heard about FITech is they’re customer support sucks. I’ll be using this with a thirdgen LS turbo kit from CXRacing. I started a thread on the install (link below) and TGO member customblackbird weighed in with some info and positive comments on his FITech system.
https://www.thirdgen.org/forums/powe...-ls-based.html
First time was when I was first installing it. The throttle blade set screw and spring were loose in the TB bag. I asked what the initial setting should be, they gave me a general setting to get it started. The instructions detail how to set it once you get it running, so that setting isn't critical until after you get it running.
Second time was when I was ready to start it, and it wouldn't fire. No trouble codes being set. They talked me through the initial settings and what I was seeing, it wasn't seeing the crank speed. I had put in a new crank sensor while installing the system, I was afraid I had gotten a bad one. He suggested first reinstalling the base program (which can be done from the handheld itself). After resetting the initial settings (CID, injector size, cam size, 24x or 58x, etc.), it started seeing the crank speed. After that, it fired right up. I've heard that one other person who had the same issue at initial startup.
Third time involved the TCC lockup - it didn't. He asked if I had the brake sense wire attached (I did), then asked how I set it up. The instructions just say to attach the wire to the brake switch. Turns out it is just like factory, wants to see 12v when the brake isn't applied, 0v when it is. I used a relay to do that with the factory system, but since the instructions weren't specific, took it out and just attached it to the brake light switch so that brake-on = 12v to the PCM - which was backwards. Put a normally-closed relay back in there, works fine now.
So, I wouldn't say their customer support is bad (their hours could be better), I probably spent 5-10 minutes on hold before someone picked up. But they knew what to do each time. The install documentation is what I would say is lacking.
I was directed here by General Disorder when the the discussion around GM crate offerings (ZZ350 vs L31-R) and my approach to making this happen with my existing carb setup. I had suggested too that the proposed LS swap that may happen, might also go carb as I have what is needed to make it all work.
https://www.thirdgen.org/forums/tech...ong-block.html
My question to this thread is to what extent is the FiTech system self learning? (I've done zero research on this). Are there options available to download the tune to a laptop and make detailed changes? Curious on this because we've had issues with self-learning systems in that they don't offer enough flexibility when it comes to certain parts of the tune.
Thanks in advance.
Thanks in advance.
I haven’t thoroughly investigated tuning from a laptop. The software they offer on their website appears to be for the throttle body system. I haven’t “needed” the capability, I actually was looking for charting software of data logs.
The initial settings take into account the properties I mentioned. They probably aren’t critical (crank sensor type being an exception), but will make initial startup quicker and easier - and tuning quicker. I haven’t experimented with that, though, just set things initially as suggested.
I have adjusted things such as WOT shift points, knock sensor authority (reduced how much timing it could pull - when running E85, I was getting knock retard with only 11.3:1CR, meaning I was getting spurious knock sensing; I disconnected the knock sensors and took the trouble code out of the programming in the factory setup), idle speed, A/F ratio at WOT, TCC speed vs. TPS lockup. Without having it in front of me, I can’t say what all else you can set, but I can say it’s more than what I know to how adjust.
I’ve done the adjustments with a combination of seat-of-the-pants feel (like TCC settings); and data logging, downloading, reading, and adjusting the tune with the handheld. It would be nice to live datalog, or tune from the laptop, but if those capabilities exist, I haven’t discovered them yet. Perhaps over the winter I can figure that out.
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
I'm running their ultimate LS (70050) kit on an SBC using EFI Connections 24x kit. I've put a couple hundred miles on it and absolutely love it so far. Zero issues, driveability is great, even with a relatively large cam and manual transmission. I had to change some connector ends and repin the injectors and coils for the firing order. Fired immediately on first start with cam 3 selected. Coldest I've started it has been 30 degrees outside, and it had no issues. The only changes I've made to the tune so far have been adding a few degrees of timing, and increasing the acceleration enrichment. I'm using 2 96-97 LT1 knock sensors.
I’m considering that in conjunction with the HiRam in a future upgrade. But with transmission controller.
My son has an MS3 in a stock LS1. He started with "2" as well.
If that gives you some idea about how much cam they can handle.
Car: 1988 Iroc-Z
I've called customer support 3 times:
Third time involved the TCC lockup - it didn't. He asked if I had the brake sense wire attached (I did), then asked how I set it up. The instructions just say to attach the wire to the brake switch. Turns out it is just like factory, wants to see 12v when the brake isn't applied, 0v when it is. I used a relay to do that with the factory system, but since the instructions weren't specific, took it out and just attached it to the brake light switch so that brake-on = 12v to the PCM - which was backwards. Put a normally-closed relay back in there, works fine now..
Note what I said earlier:
So the brake light switch wire I used for the FiTech system isn't the same as our 3rd gens.
However, you should be able to find a wire that is powered when the brake isn't depressed, and isn't powered when the brake is depressed. It's used for the cruise control, the top switch in your photo. So you don't need the relay.
Installed one of the LS harness and ECM kits in April. I went into it with relatively low expectations. Mainly because we've had friends running the "self learning" Holley systems for years and they always seemed to need a tuner anyway. This one actually fired up and started learning immediately. It won't tune timing but you can set that manually either on the handheld or a laptop. But it does come with timing tables mapped to the cam settings of 1 - 4. With the dual widebands it corrected the AFR quickly and was driveable almost immediately after getting the IAC set properly. In all, I'm very happy with the system. And it's cost competitive with a factory system plus tuning.
Car: 1988 Iroc-Z
Car: 1988 Iroc-Z
That's a nice GTA you have there! I was looking at that Facebook link you have, what kind of exhaust do you have on the car? I was able to get my car to start right away as well with the FiTech system but haven't taken it for a ride yet and still having some troubles with idle.
I may eventually have it completely redone with dual 2.5 inch out the back with multiple muffler options to meet sound. But not yet.
The red GTA doesn't run the FiTech system. It has a 0411 PCM from a 2002 Camaro in it. The next engine I build for it will likely use the FiTech system. The FiTech went on the grey Camaro we built to run west coast events while the GTA is on the east coast. Mechanically they are identical with the same motor and transmission specs.
