5.3 Swap Fuel System Help
Old Mar 30, 2017 | 08:21 PM
Chase_Crew91's Avatar
Car: 1991 Camaro RS (WS6/Iroc Clone)
Engine: 5.3 LSX
Axle/Gears: 3:73 Richmond
Hey everyone,
I am in the middle of trying to upgrade the fuel system in my 91 RS to support the 5.3 i am putting in. I bought a new sending unit for the 3rd gen tank and a walbro 400, which in retrospect is probably way to much for the slightly modified motor im putting in.
The new pump will require modification to work with the current sending unit I have. What are some recommendations on either getting a smaller pump or modifying the sending unit?
All advice is welcomed.
Old Apr 5, 2017 | 01:15 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 5.3 Swap Fuel System Help
Unless you're going wild with the 5.3, a Walbro 255 TPI replacement pump should do fine.
Old Apr 5, 2017 | 01:53 PM
Engine: 5.3 LSX
The motor has been fully rebuilt, ARP everything, forge internals, LS6 cam, injectors, springs, and I had them set the piston rings up to support boost. My goal is to get the car drivesble this year and put a twin turbo set up on it next year.
Old Apr 5, 2017 | 04:06 PM
five7kid's Avatar
You'll probably need more pump for twin turbo.
Old Apr 6, 2017 | 11:42 AM
indebt's Avatar
Yeah a 255 would be fine for now. Dual 450's if going twin turbo. There's threads in the Power Adder forum for dual pump install's and a single 450.
